455 won't start...but it cranks
   / 455 won't start...but it cranks #11
My 455 did something similar, long story short it ended up being a loose ground on the fuel shutoff solenoid. Remove the left side panel and you will see it. My problem started as a coughing/sputtering problem, turned into a "won't start" problem before I found it.
   / 455 won't start...but it cranks #12
The fuel solenoid pull-in coil is high current. Could be up to 5 amps. If you have a poor connection someplace along the current path, then the pull-in may not operate and thus, no start.
I agree with other posters. Corroded connectors, poor crimp or just a poor ground can become a problem.
Keep looking.
Richard
   / 455 won't start...but it cranks #13
I have the problem in the morning .you crank it and crank it maybe half hour then it starts. then it works good all day. I usally trouble shoot it myself this time had jd mechanic look at . he thinks its a sensor hopefully it is
   / 455 won't start...but it cranks #14
I believe OP found a bad fuel shut-off but you said something that might interest owners. A mechanic should have knowledge of testing proceedures and know what's wrong. Dealer that throw parts at it until fixed is a hack,not a mechanic. Owners can buy and install parts themselves much cheaper than paying $80-$100 per hour plus mark-up on parts. As you said "hopefully"he's right the first time.
   / 455 won't start...but it cranks #15
was on a job didn't have time to look at it . ill post what outcome from it .lol and its 120 per hour and will not be allowing guess work for sure.
   / 455 won't start...but it cranks #16
   / 455 won't start...but it cranks #17
1400 hr 2011 jd tractor
   / 455 won't start...but it cranks #18
diesal
This must be your listed 4720 and not the 455 model in the subject of the thread.. ??
   / 455 won't start...but it cranks #19
that's right 4720 2011 jd
   / 455 won't start...but it cranks #20
once I get it going it stays working . ive been using it 12 hrs a day snow removal . 10 days now .it works the very best when it starts . reading up on the manual now
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
Metal Donkey Statue (A55758)
Metal Donkey...
2018 Sea Pro Boat with S/A Trailer (A55758)
2018 Sea Pro Boat...
20'x30' All Steel Carport (A53316)
20'x30' All Steel...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
6' Blade (A53316)
6' Blade (A53316)
