Big cities are dying. This should shock you.
Status
Not open for further replies.
   / Big cities are dying. This should shock you. #201
Cali is a truly beautiful state, but many of the people there ruin it
   / Big cities are dying. This should shock you. #202
I first mentioned this scenario in post #44
There is a lowes in a older/ kinda bad part of town here. They have an exterior electrical outlet on each side of the building. There's always a heroine head squatting next to the outlets with their phone plugged in.
I would be disconnecting those outlets if it were my store.
   / Big cities are dying. This should shock you. #204
My Dad pulls up to Walmart in his Sprinter and runs a cord to their receptacle to run his water kettle for a shave and some instant coffee. I always wonder if he unplugs their softdrink machines.
Back in the days when corded leaf blowers and trimmers or what ever were used, stores my have needed external outlets but I do not see the reason today.
   / Big cities are dying. This should shock you. #206
I have... after first installing stainless cover plates with tamper proof screws that have been overcome with force.
Interesting we were required at the time of new construction to provide several outdoor outlets... all have proved problematic due to the street population with consumer electronics..
I was called into work on a Sunday morning once because of the smell of cooking... upon investigation... I found a street person had set up camp on the roof on one of the hospital buildings and was using a hot plate cooking bacon and eggs near a HVAC intake... so the smell was carried through the area... the roof to meet building code had several outlets.
The only permanent solution was for me to trace the wires to j-boxes inside the building and disconnect the feed to the outside boxes...
This is about the time the street people started splicing into the street light power access plates at the street light pole base...
   / Big cities are dying. This should shock you. #207
We used the ground level exterior ones for Health Fairs... and occasionally I used one to run a sewer cable machine...
The field of roof mounted ones is extensive... the idea it for those servicing rooftop equipment to have readily available power....
What is to worry about, if they caught the roof on fire their urine and feces may put it out. I hope you found out how they got up there.
   / Big cities are dying. This should shock you. #209
Adjacent to the property is a shopping center and for about 250' the rear of a row of shopping center building and the Hospital are separated by a narrow ally...
A plank was sued to span the 10' distance to get from the shopping center roof to the hospital roof.
The shopping center has had several run in with rooftop metal bandits... cutting out the copper and aluminum from package units to sell for scrap...
I have been more fortunate but have had the entire backflow main water supply assembly stolen for the $20 in scrap it would bring... an entire hospital without water from copper thieves... plus the geyser of water shooting past the roof line...
I got a call at 1 am saying the toilet on one floor did not work so the nurse took her patient to another an it did not work and then they found none of the toilets or faucets worked...
   / Big cities are dying. This should shock you. #210
Unbelievable! If a society tolerates that kind of people running around, it pretty much gets everything it deserves. And once again, the few hard working people left, get to pay for it all.
Status
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
500BBL WHEELED...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
