Rear Finish Mower Parts for LS 84 finish mower
   / Parts for LS 84 finish mower #1
davejstl
Cedar Hill, MO
TYM T394 HST; Cat 259B3 skid steer
I have an 84 LS finish mower (model # LFMP84), and I can稚 seem to find parts for it online. The main thing I need for now is a blade, but it seems to be an uncommon size.
Suggestions? I do have a local (45-60 min away) dealer, but was already there yesterday and didn稚 want to make that trip again so soon.
   / Parts for LS 84 finish mower #2
Sometimes you can match up blades with other brands need length center hole size and direction of rotation try mowpart.com they have a good selection
   / Parts for LS 84 finish mower #3
You can try RCO tractor in Austin, they do ship. Just google RCO tractor
   / Parts for LS 84 finish mower #4
Old post ...... but I think I've found a solution on blades for the LS 84" RFM.
The last set of OEM blades I bought were $205 for a set of 3 blades.
The LS Blades are 28 3/4" long with 3/4" mounting hole. And a 1" drop.
Oregon #92-302 are identical except length which is 28 9/16" or 3/16" shorter. That only 3/32" shorter radius.
The blade overlap is 1 3/16" so, the shorter blade should have no effect.
Oregon also has a Gator Mulching Blade #392-302 with sale length, etc as the #92-302.
Oregon Parts Store Quality Replacement Parts
Oregon has $9.95 shipping so;
A set of 3 x #92-302 would be about $59.
A set of 3 x #392-302 would be about $80.
   / Parts for LS 84 finish mower #5
Update;
The Oregon Blades work great!
Let me know how they cut? The standard blades result in pretty fine clippings.
Thanks for your research on those part numbers. I also went with the regular blades on mine. I feel like the cut quality is fine, but the mower seems to get bogged down more than I'd expect. If my grass gets a little too tall, our 5' zero-turn cuts faster or I just go to the rotary cutter.
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2013 Land Rover Range Rover Sport 4X4 SUV (A51694)
2013 Land Rover...
BLACK DIAMOND AIR COMPRESSOR (A53843)
BLACK DIAMOND AIR...
John Deere Motor Grader (A52377)
John Deere Motor...
2002 Ford F-350 Crew Cab Flatbed Truck (A51691)
2002 Ford F-350...
