Rear Finish Mower Parts for LS 84 finish mower
   / Parts for LS 84 finish mower #1
davejstl
Cedar Hill, MO
TYM T394 HST; Cat 259B3 skid steer
I have an 84 LS finish mower (model # LFMP84), and I can稚 seem to find parts for it online. The main thing I need for now is a blade, but it seems to be an uncommon size.
Suggestions? I do have a local (45-60 min away) dealer, but was already there yesterday and didn稚 want to make that trip again so soon.
   / Parts for LS 84 finish mower #2
Sometimes you can match up blades with other brands need length center hole size and direction of rotation try mowpart.com they have a good selection
   / Parts for LS 84 finish mower #3
You can try RCO tractor in Austin, they do ship. Just google RCO tractor
   / Parts for LS 84 finish mower #4
Old post ...... but I think I've found a solution on blades for the LS 84" RFM.
The last set of OEM blades I bought were $205 for a set of 3 blades.
The LS Blades are 28 3/4" long with 3/4" mounting hole. And a 1" drop.
Oregon #92-302 are identical except length which is 28 9/16" or 3/16" shorter. That only 3/32" shorter radius.
The blade overlap is 1 3/16" so, the shorter blade should have no effect.
Oregon also has a Gator Mulching Blade #392-302 with sale length, etc as the #92-302.
Oregon Parts Store Quality Replacement Parts
Oregon has $9.95 shipping so;
A set of 3 x #92-302 would be about $59.
A set of 3 x #392-302 would be about $80.
   / Parts for LS 84 finish mower #5
Update;
The Oregon Blades work great!
Let me know how they cut? The standard blades result in pretty fine clippings.
Thanks for your research on those part numbers. I also went with the regular blades on mine. I feel like the cut quality is fine, but the mower seems to get bogged down more than I'd expect. If my grass gets a little too tall, our 5' zero-turn cuts faster or I just go to the rotary cutter.
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
Pitts RGN Trailer (A50322)
Pitts RGN Trailer...
