Rear Finish Mower Parts for LS 84 finish mower
   / Parts for LS 84 finish mower #1
davejstl
Cedar Hill, MO
TYM T394 HST; Cat 259B3 skid steer
I have an 84 LS finish mower (model # LFMP84), and I can稚 seem to find parts for it online. The main thing I need for now is a blade, but it seems to be an uncommon size.
Suggestions? I do have a local (45-60 min away) dealer, but was already there yesterday and didn稚 want to make that trip again so soon.
   / Parts for LS 84 finish mower #2
Sometimes you can match up blades with other brands need length center hole size and direction of rotation try mowpart.com they have a good selection
   / Parts for LS 84 finish mower #3
You can try RCO tractor in Austin, they do ship. Just google RCO tractor
   / Parts for LS 84 finish mower #4
Old post ...... but I think I've found a solution on blades for the LS 84" RFM.
The last set of OEM blades I bought were $205 for a set of 3 blades.
The LS Blades are 28 3/4" long with 3/4" mounting hole. And a 1" drop.
Oregon #92-302 are identical except length which is 28 9/16" or 3/16" shorter. That only 3/32" shorter radius.
The blade overlap is 1 3/16" so, the shorter blade should have no effect.
Oregon also has a Gator Mulching Blade #392-302 with sale length, etc as the #92-302.
Oregon Parts Store Quality Replacement Parts
Oregon has $9.95 shipping so;
A set of 3 x #92-302 would be about $59.
A set of 3 x #392-302 would be about $80.
   / Parts for LS 84 finish mower #5
Update;
The Oregon Blades work great!
Let me know how they cut? The standard blades result in pretty fine clippings.
Thanks for your research on those part numbers. I also went with the regular blades on mine. I feel like the cut quality is fine, but the mower seems to get bogged down more than I'd expect. If my grass gets a little too tall, our 5' zero-turn cuts faster or I just go to the rotary cutter.
9202 (A50322)
9202 (A50322)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Ford 3600 Tractor (A53117)
Ford 3600 Tractor...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
