CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...?
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #1
Sid Post
TX and OK
Massey 5711D, Kubota L4600, Kubota B2601
I need to upgrade from my Kubota L4600. While a great tractor, it just isn't meeting my needs today. I need more loader capacity (~3K#'s) and more 3-pt lift capacity and, the L4600 is too narrow (3-pt) for most of my 3-pt equipment which is class 1&2 compatible. I really like its low fuel use but, it's narrow tread and high profile is a problem on the sloped land I use it on now.
I have looked at the John Deere 50x5M tractors but, they seem much more expensive for similar features and capacity. I also don't like their propietary software issues. The Kubota 7060 has the regen emissions which seems to work well but, the Case IH / NH are DPF regen free which is nice. Both have larger tires which is nice in addition to a better stance and more ground weight (L4600 is too light in the rear end).
I'm looking to stay in the low $30K's price point new and don't mind a properly maintained used tractor. What are the pro's and con's of these options? Which options am I over looking?
I have Case IH, NH, Kubota and, John Deere dealer support close by so I'm pretty brand flexible.
TIA,
Sid
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #2
Are you looking for cab or open station? I think to stay in the lower 30s new you'll need to consider LS, Kioti, TYM.
Yes, open operator station. With cabs, I'm afraid of breaking the glass or having to use it with the A/C broken.
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #4
Sid,
I know the specs say that a 75C will lift over 3000 lbs however, I have a 75a ( open station) with the L 540 loader and I will only lift just over 2000 lbs safely. So if you are dead set on needing to lift 3000 lbs you may want to look into a bit bigger tractor. Otherwise my tractor has been an excellent addition to our farm and has been extremely reliable
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #6
At your price point and need for big numbers you may want to take a look at the Rural King tractors, specifically the RK55. Branson may be worth a look as well.
RK55H Tractor | RK Tractors
Or, you might want to forget about HST and move into a utility class tractor with a shuttle shift like a JD 5075E or equivalent.
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #7
Curiously none of the three tractors in the subject line are available with hydrostatic transmission.
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #8
Very few tractors over 60-horsepower are available with HST.
Large tractors are used in long fields. Forward/reverse direction changes infrequent.
HST has decreased fuel economy relative to shuttle shift.
Shuttle shift may be cheaper to manufacture, therefore cheaper to sell than HST.
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #9
Q
I get all that, I’ve been driving tractors for 57 years and have 22 years experience at tractor dealerships, New Holland, CaseIH and Kubota. My point, which you completely missed, is that Tractorable seemed to want to move the discussion away from hydro transmissions when in fact it was never there to begin with.
   / CaseIH Farmall 75C / NH 4.75 or Kubota 7060 or ...? #10
I didn’t research the transmission options for the tractors in the subject line before posting, I just meant to bring up the point that moving into a utility class machine usually means losing the HST option.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2017 JOHN DEERE CP690 LOT IDENTIFIER 180 (A53084)
2017 JOHN DEERE...
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A53426)
2020 INTERNATIONAL...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
