B2650 I picked her up todsy
   / B2650 I picked her up todsy #11
I only use a light duty 4’ shredder on the rear of my B2650 so no problems with the front end lifting up. I can see where a larger heavy duty Rhino cutter might be a problem. What I was getting at in my post is that when shredding lumpy ground the added weight of the bucket on the front can cause jolting/pounding when the front wheels hit low spots.
   / B2650 I picked her up todsy #12
Congrats Lee nice setup :thumbsup: your things to do list just got a whole lot easier. :)
   / B2650 I picked her up todsy #13
My only con to the tractor is the lever for the FEL is a little too close to my thigh and when I shift my body to look behind me my thigh moves the FEL.
There is a little lever at the bottom of the FEL stick that will lock the stick in place. You'll be able to rest your leg against it without any issue.
Joe
   / B2650 I picked her up todsy #14
Congratulations Lee! What rotary cutter are you using with it?
   / B2650 I picked her up todsy #15
Joe
Dang, I wish I had known that the last time I was using the back blade to move snow with the FEL mounted............
I kept moving the joy stick with my leg as I looked back. Now, If i can remember that the next time.
Thanks Bubba .....
Mike
Thanks Joe! I'll look for that lever.
Joe
   / B2650 I picked her up todsy #18
RCR 1260? It's doing a nice job on them!
Yale Veracitor 135VX Yale 12,150lb Forklift (A50322)
Yale Veracitor...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
John Deere Z915B (A50121)
John Deere Z915B...
1999 Toyota Avalon Sedan (A50324)
1999 Toyota Avalon...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
