B2650 I picked her up todsy
   / B2650 I picked her up todsy #11
I only use a light duty 4’ shredder on the rear of my B2650 so no problems with the front end lifting up. I can see where a larger heavy duty Rhino cutter might be a problem. What I was getting at in my post is that when shredding lumpy ground the added weight of the bucket on the front can cause jolting/pounding when the front wheels hit low spots.
   / B2650 I picked her up todsy #12
Congrats Lee nice setup :thumbsup: your things to do list just got a whole lot easier. :)
   / B2650 I picked her up todsy #13
My only con to the tractor is the lever for the FEL is a little too close to my thigh and when I shift my body to look behind me my thigh moves the FEL.
There is a little lever at the bottom of the FEL stick that will lock the stick in place. You'll be able to rest your leg against it without any issue.
Joe
   / B2650 I picked her up todsy #14
Congratulations Lee! What rotary cutter are you using with it?
   / B2650 I picked her up todsy #15
Joe
Dang, I wish I had known that the last time I was using the back blade to move snow with the FEL mounted............
I kept moving the joy stick with my leg as I looked back. Now, If i can remember that the next time.
Thanks Bubba .....
Mike
Thanks Joe! I'll look for that lever.
Joe
   / B2650 I picked her up todsy #18
RCR 1260? It's doing a nice job on them!
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
John Deere Front Weight (A50515)
John Deere Front...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2015 Ford F-150...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52141)
1999 KENWORTH W900...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
