check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,164
- Tractor
- 2009 Kubota BX25
Was it recently level with the water?
Yes it was perfectly level, Jay, back in the early spring when the water level was down, just before the Spring runoff. (The water in our lake rises a good 3 ft. to it's normal Summer level during the Spring runoff.) I have now figured out what the problem is. The top 3 or 4 or 5 layers of new 6 x 6's are sitting on top of the old Cedar crib, which is still sound, and will be long after I am gone. The problem is that I haven't attached them yet, because I am still making adjustments. So, that outer end just floated up! Big surprise, but no problem, because the other end is underneath the wall of the boathouse. Anyway, I can just make a bit of a platform and place some flat rocks on it for now, because it is just barely floating. (I can step on that high corner and push it down quite a bit.) Then in the fall I will finish attaching the new top structure to the old. In any case, it is certainly not going even want to float once I get all the PT 2 x 8 decking on.
