80mm hole to 90mm in 1/4" steel
   / 80mm hole to 90mm in 1/4" steel #11
   / 80mm hole to 90mm in 1/4" steel #12
Is there a way to bolt or clamp metal behind the hole? If so, it could be drilled pilot size first (1/4") for a hole saw.
Very clever. I'll remember that one. And also the trick about mounting two hole saws one inside the other. That would work with a wooden plug around the pilot drill too.
rScotty
old dog; new tricks
   / 80mm hole to 90mm in 1/4" steel #13
If you use a predrilled backer to pilot the hole saw, then you can also swap out the pilot bit for a chunk of 1/4" rod. Won't enlarge your pilot hole, less likely to break, and if it does it's not as spendy as a drill bit...
   / 80mm hole to 90mm in 1/4" steel #14
i have used 3/4 plywood. drill the center, clamp to part, use hole saw. the Milwaukee hole saws are pretty good. you want a pretty coarse tooth. Think of it as a band saw blade wrapped in a circle. you don't want the blade to remind you of a hacksaw blade. lots of little teeth load up fast and get over heated fast because they cant clear the gullet of chips and the cutting pressure per tooth is very low. The rule for a bandsaw is having at least 4 teeth and not more than about 10 in the part at one time.
   / 80mm hole to 90mm in 1/4" steel #15
One could make a "template" and use the torch or plasma cutter in the template, (I guess it depends on how exact you need the hole),
Maybe letting us in on the use of these hole would help,
   / 80mm hole to 90mm in 1/4" steel #16
I have also used a torch to rough it out then use a used grinder wheel to shape it .
   / 80mm hole to 90mm in 1/4" steel #17
Plasma cutter with a wood template. You will get a decent clean hole, then a little grinding. Of if you can get your hands on one, a magnetic drill press. Very handy, wish I had one.
   / 80mm hole to 90mm in 1/4" steel #18
This is what I have used with great success in the past and will work for your exact situation.
It's called the "OOPS Arbor" by Starrett although I'm sure this type of arbor is available from other manufacturers.
The hole-saw arbor can accommodate 2 cutters being used at the same time. One cutter, inside, for the original hole size and one cutter, outside, for the newer, larger size hole. Finding your "exact" hole sizes for the cutters may be a fun journey... ;-)
3 things:
1. Buy the best quality hole-saw cutters you can afford - "inexpensive" hole-saws do not hold last! "Quality is long remembered after the price is forgotten."
2. Use a good quality "tapping / cutting oil" and lots of it.
3. Stop the cut when about 1/2 or 2/3 of the way and remove the inner, smaller cutter and only then continue with the new, bigger hole. This will allow for the continuation of the larger hole cutting without trapping the small section between the 2 cutters. 1/2 to 2/3 the way through the new cut will allow for the cut to be finished after the inner cutter is removed. Easy Peasy!
   / 80mm hole to 90mm in 1/4" steel #20
3 things:
Excellent idea! thanks for sharing
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
