Homemade atv brush cutter blade RPM???
   / Homemade atv brush cutter blade RPM??? #1
cormier
New Brunswick Canada
Challenger MT275
Hey guys i'm building a homemade 40" 16hp pull behind atv brush cutter. I am going to use it of food plots for deer hunting.It will be cutting some small saplings 1/2"or less but mostly grass. It`s to tight of a trail to get my tractor in their so i`m building a small one for my ATV. anyhow i am looking for the proper RPM the blades should turn so i can figure my belt ratios i need to make cut efficiently?
   / Homemade atv brush cutter blade RPM??? #2
I've seen 11-16k feet per minute blade tip speed advertised, work backwards from there. If you anticipate rocks and stumps you'd probably want swinging blades.
Product Details
Product Details
   / Homemade atv brush cutter blade RPM??? #3
I figured 12000 feet per second blade top speed when I built an 8 foot 3 blade mower. I used trailer axle hubs and had 6 spindles made at a local machine shop. Figured I could use the extras for spares. Traded the mower to an electrician so i never got to run it. He was happy with it.
David from jax
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A55787)
2009 Yale...
2019 Chevrolet Tahoe 4x4 SUV (A55758)
2019 Chevrolet...
