Homemade atv brush cutter blade RPM???
   / Homemade atv brush cutter blade RPM??? #1
cormier
New Brunswick Canada
Challenger MT275
Hey guys i'm building a homemade 40" 16hp pull behind atv brush cutter. I am going to use it of food plots for deer hunting.It will be cutting some small saplings 1/2"or less but mostly grass. It`s to tight of a trail to get my tractor in their so i`m building a small one for my ATV. anyhow i am looking for the proper RPM the blades should turn so i can figure my belt ratios i need to make cut efficiently?
   / Homemade atv brush cutter blade RPM??? #2
I've seen 11-16k feet per minute blade tip speed advertised, work backwards from there. If you anticipate rocks and stumps you'd probably want swinging blades.
Product Details
Product Details
   / Homemade atv brush cutter blade RPM??? #3
I figured 12000 feet per second blade top speed when I built an 8 foot 3 blade mower. I used trailer axle hubs and had 6 spindles made at a local machine shop. Figured I could use the extras for spares. Traded the mower to an electrician so i never got to run it. He was happy with it.
David from jax
2005 Freightliner M2 106 Ambulance (A55788)
2005 Freightliner...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
John Deere BD1108 (A50123)
John Deere BD1108...
10ft Enclosed Cargo Trailer (A53424)
10ft Enclosed...
John Deere 643 6 Row Corn Head (A50775)
John Deere 643 6...
