Homemade atv brush cutter blade RPM???
   / Homemade atv brush cutter blade RPM??? #1
cormier
New Brunswick Canada
Challenger MT275
Hey guys i'm building a homemade 40" 16hp pull behind atv brush cutter. I am going to use it of food plots for deer hunting.It will be cutting some small saplings 1/2"or less but mostly grass. It`s to tight of a trail to get my tractor in their so i`m building a small one for my ATV. anyhow i am looking for the proper RPM the blades should turn so i can figure my belt ratios i need to make cut efficiently?
   / Homemade atv brush cutter blade RPM??? #2
I've seen 11-16k feet per minute blade tip speed advertised, work backwards from there. If you anticipate rocks and stumps you'd probably want swinging blades.
Product Details
Product Details
   / Homemade atv brush cutter blade RPM??? #3
I figured 12000 feet per second blade top speed when I built an 8 foot 3 blade mower. I used trailer axle hubs and had 6 spindles made at a local machine shop. Figured I could use the extras for spares. Traded the mower to an electrician so i never got to run it. He was happy with it.
David from jax
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2006 CHEVROLET EXPRESS SERVICE VAN (A56138)
2006 CHEVROLET...
2013 South GA Cargo 24ft T/A Enclosed Cargo Trailer (A55758)
2013 South GA...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
