How to grow grass
   / How to grow grass #11
I've had to "convert" wooded acreage to yard acreage over the past couple of years.
One of the best things you can do is get a soil test. Take small samples from several locations around your "other" area. Mix it together and take it to your county extension, college, or lawn supply retailer to have the test done. Usually less than $10. Then you'll get a report that tells you what nutrients you need to put on the soil to get it balanced. Could save you a ton of money if you're putting the wrong stuff on it. You might only need to apply a couple of applications of 10-10-10, or maybe you need lime, or maybe you need ?????? Soil test will be a big help to get you on track right away.
Live with the weeds this year, and til after you get the grass growing next season. Then you can go over the acreage with a weed only killer (not glyphosphate). TSC has a pretty good weed killer called Trimec that worked great for me, if you have access to someone with a boom sprayer.
Keep it mowed on the short side to allow the sun to get to the resident grass. If you're going to over-seed, cutting it short will assist in the germination of your new seed. If you're going to over-seed see if you can find something to score the top of the dirt just a little, like a spike tooth harrow/drag. I wouldn't disk it up, as you would lose a lot of your current grass.
Talk with your local yard supply store, and see what grass they recommend you use, if you only want to mow/bush hog every 3-4 weeks.
   / How to grow grass #12
I have an area that was overgrown with all sorts of weeds and small trees. I ran over it with my field and brush mower a couple of times, then started mowing it regularly. No weed treatments or fertilizers. For some reason, it's now better 'grass' than my front 'lawn' area. So much better that I've been trying to find a way to cut sod sections from it for replanting out front in weaker sections.
My experience has been the same. When I bought my place about 3.5 acres was what I called "field". High grass, weeds and briar bushes. Only a small piece had been mowed regularly but the piece visible from the road had been let go. I had a friend brush hog it for me and then started mowing every week. Within a year it looked like a lawn for the most part. Now, 4 years later there is no trace of the weeds and briars left, only grass. In some ways I regret reclaiming it. It is a nightmare to mow every week(too steep for a Zturn) but it looks way nicer and had a huge impact on the overall appearance of the house.
   / How to grow grass #13
Now that is brilliant advice...I'm in the same boat as the OP, so this will help tremendously. Thanks!
TXCOMT
   / How to grow grass #14
I thought this thread was going to be dealing with the new marijuana laws. I was wrong. :laughing: :D
   / How to grow grass #15
Watering if it doesn't rain, is EVERYTHING! It can be exhausting. Close to a house, at least you should have your water supply for hoses and sprinklers. Once the seed gets wet, you are pretty much commited to keeping the area from drying out.
   / How to grow grass #16
the OP hasn't clarified that, but. due to Political fighting, Recreational Marijuana(grass) is not yet legal, so the OP should hold off on this until it's fully legal!..
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2017 Chevrolet Tahoe, 179,380 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2017 Chevrolet...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2022 John Deere Z930M (A57148)
2022 John Deere...
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
