rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,583
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I've done lots of tire swaps over the decades and only two methods work for me. One is to use the factory tire size and it will always be correct. If you can't do that, you have to get the front axle ratio one way or another from a dependable source such as a manual or the manufacturer. If you can't find it in a shop manual, just keep calling the factory and try to talk with an engineer. It might take a while but eventually you'll get someone that knows something, if for no other reason than to stop you from calling. Short of an answer from an engineer, I want to see the ratio in print somewhere and not word of mouth from someone that says they know. Use the rolling circumference numbers from the tire maker's site when you get the ratio.
Little known fact here is that I have seen new Kubotas with the axle ratio on a sticker on the back of the seat. Go figure.
We ought to do a sticky on this site with the confirmed axle ratio of various models and the source for the number. It would make things easier.
I'd approach it differently: I believe that the only really reliable way to know the real ratio is to measure the 4wd axle ratio for yourself - as we've laid out.
A manual, a reference in print, or an engineer at the manufacturer can only tell you what they think it should be... That may or may not be what you have on your tractor, and it may vary by which optional tire and wheel set was on the tractor when it was originally built. In fact, that would be one reason for finding the axle ratio on a sticker on the back of the seat - and just hearing that makes me uneasy.
There is no way short of measuring your tractor's internal axle ratio to confirm what is in your own tractor.
By measuring it yourself you can tell what your internal ratio really is. Anything else is a guess.
rScotty
