B2150hst 4WD Tire Help - Lead/Lag Mechanical Ratio
   / B2150hst 4WD Tire Help - Lead/Lag Mechanical Ratio #31
Do you have "Bi=Speed" turn on your B2150 ?
   / B2150hst 4WD Tire Help - Lead/Lag Mechanical Ratio #32
I probably should have been more specific when saying "load". I was thinking in terms of draft load.
Yes a heavy draft load will cause a small loaded radius decrease in the rear,
not as much as a heavy lift arm load.
It can also unload the front axle a small amount which could slightly increase the loaded radius.
No bi-speed.
Did not have time on Sunday to lift tractor and measure physical ratio. It was the last burn day of the season and needed to clear brush. Not sure when I can do the ratio test but it will happen so maybe other B2150 owners in the future can use the information.
Coleman Go Cart (A51573)
Coleman Go Cart...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
