Mahindra 750b XTV will not start
   / Mahindra 750b XTV will not start #1
The Wife
Mahindra 705b XTV Side by Side
Our Mahindra side by side will not start. I left the key on and the battery died. Replaced the battery, cables are on correctly. Checked fuses, none bad. Have power coming from battery, thru 80 amp fuse on battery cable. When ignition key is turned, nothing happens. No self check, no lights, absolutely nothing. At a loss, possibly the ignition key? Any and all suggestions appreciated. Thank you in advance. Also posted in ATV/UTV forum
   / Mahindra 750b XTV will not start #2
One of the cables isn’t making a good connection. Test with Ohms instead of volts.
..:.:::unless you shorted something replacing the battery. Then it’s a methodical process.
RNeumann, thank you for your reply. It seemed liked it would be a bad connection to me also. I did find the solution with help from the Big Tex Agriplex dealer nearest me. It seems I had two of the battery cables installed incorrectly. It goes against everything I was taught to put a black cable on a positive battery post. But that is exactly what needed to be done. After reconnecting correctly, voila, everything works as it should.
   / Mahindra 750b XTV will not start #4
You are lucky. I'm shocked something didn't get blown up. Any time I ever hook something up backwards, it blows up!
   / Mahindra 750b XTV will not start #5
Good deal The Wife, :confused2: were both cables black?
   / Mahindra 750b XTV will not start #6
Dont know anything about the Mahindra 750 B xtv but heard there made by Intimidator whoever they are ?
Molalla1...There were 2 large black cables, 1 smaller black cable and 1 red cable. The red cable and a large black cable are connected to the positive side and a large black cable and small black cable are connected to the negative side. One other thing that threw me was the cables that should go together on the battery terminals are zip tied to another cable but not it's terminal mate, if that makes sense. But thank the Lord it's back working right and I have my ride back,
   / Mahindra 750b XTV will not start #8
:thumbsup: . . . well that will not happen to you again! and welcome to TBN The Wife.
Thank you Molalla1 😃
2007 Ford E350 (A55973)
2007 Ford E350...
Jaw Crusher (A59228)
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
