Importance of Engine Displacement when Comparing SCUT/CUTS?
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #1
Otto33
Member
Mid-MO
LS MT 225s
Is there any practical benefit in choosing a tractor with a larger/smaller engine when the HP is maxed at 24.5?
I'm looking specifically at the Kioti CK2510 with a 100CI/1637CC engine vs a Kubota B2601 with a 68.5CI/1123CC engine. So, a roughly 30% smaller engine for the Kubota. Even the B3350 has a smaller engine than the Kioti despite the relatively large difference in HP.
I know that, all other things being equal, a larger engine should have more available torque at lower revs, but is that advantage completely lost when discussing PTO driven implements?
Or, with machines this small, is the extra displacement just a waste of fuel?
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #2
im not a huge tech guy when it comes to things. But you got cams, injection, breathing, exhaust, material of the block, heads, all this stuff makes a difference. The days of bigger engine means its better are long gone. my 98 chevy was a 5.7 and produced 250hp give or take, my 19 ford is a 5.0 and produced almost 400 hp.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #3
Kubota equivalent to Kioti CK2510 is the Kubota L2501, which is a little heavier and has a three (3) range HST transmission.
Kubota B2601 is 1,632 pounds bare tractor with a three (3) range HST transmission.
Kubota L2501 is 2,623 pounds bare tractor with a three (3) range HST transmission.
Kioti CK2510 is 2,260 pounds, bare tractor with a two (2) range HST transmission.
The Kioti CK2510 needs the 100 cubic inch engine to move its additional 600+ pounds.
On sloping land, with a flail mower and an FEL you may want the lower/LOW of a three (3) range HST regularly.
All three tractors above are considered compact tractors based on 12" ground clearance.
(Subcompact tractors have 7" to 9" ground clearance.)
Compact tractors with relatively large diameter wheels/tires have more tractive power pulling ground contact implements, pushing a loader buckets into dirt and pushing snow. Larger wheels and tires permit bridging holes, ruts and tree debris with less operator perturbation.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. Spreadsheet tractor and implement specs, often a revealing exercise.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second and (narrowly) rear wheel ballast third.
I appreciate the replies. My comparisons definitely muddied the waters more than I intended.
The question I should have posed was, at the same HP rating, will tractors of comparable size/weight have comparable abilities, regardless of engine displacement?
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #5
I don’t think it makes any difference. A turbo vs no turbo at equivalent hp might be a difference.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #6
If you’re going to play that game, be sure to include the Kioti CK 2610 in the comparison: it outweighs both the Kubotas at 2701 lb, has a 3 range hst, and the larger displacement100 cu in engine.
The fundamental importance... bla, bla, bla.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #7
I don't think it makes any difference either. Horsepower is a function of torque times RPM's. You will generally find that a smaller displacement engine will make it's rated horsepower at a higher RPM than the larger engine, unless it's turbocharged. There are different ways of designing engines and both of these approaches should be fine for our uses.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #8
The difference in displacements determine at what rpm the hp is developed. I had a 25 (24.7) HP SCUT with a 77.3cc displacement. It's HP was made at 3100. My new LS compact 25 (24.6) HP has 80.4cc displacement, but makes its HP at 2500 rpm. Even for the basically the same HP, the compact makes more PTO HP (just a little) but definitely feels like it has more torque. I'm not sure of the actual torque numbers.
You mentioned fuel usage... My slightly larger displacement tractor (much bigger tractor overall too) uses less fuel than the SCUT did.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #9
If youæ±*e going to play that game, be sure to include the Kioti CK 2610 in the comparison: it outweighs both the Kubotas at 2701 lb, has a 3 range hst, and the larger displacement100 cu in engine.
Yeah or the new Branson 2515H if it ever gets to the dealers.
outweighs the Kubota and the kioti
has a 3 range hydo with throttle link
1.7 litre engine
2400lb 3 point lift @ 24 inch behind the ball ends
2200lb at the pin to 104 inch BL 150 FEL lift
https://www.tractorbynet.com/forums...240_680335079049497_6629914584159354880_n-jpg
If /when Branson actually delivers
Rated RPMs can make a big difference
as an example my old chinese tractors engine was also available in boats and they cranked the tractor which was rated @2000 to 2800 rpms for boat use
800 RPM added over 20 HP to the data plate
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #10
I just bought a JD 2025R which has a 1.3 liter 25hp and traded in a Kubota BX2350 with a 0.9 liter 23 hp. I知 not disappointed with the power of the JD but there is not as much difference as I thought in spite of the larger engine. In other words the larger displacement makes less difference than I thought.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #11
HP for moving the tractor around isn't that much of a discriminator when comparing tractors in the same general range. Case in point, Kubota makes a 26HP BX2680 SCUT and a 26 HP B2601 series tractor. The B is a physically larger tractor and has more capability but same engine HP. Why? Because its less about engine HP and more about the size and flow rate of the hydraulic pumps and PTO HP.
Tractor speed and torque can be optimized with transmission gearing. With HP rating at the PTO.....Will you run PTO driven implements? Typically, higher engine PTO equates to higher PTO HP. That said, mileage varies. Kubota has efficient engines that put a higher percentage of engine HP to the PTO shaft. JD tends to have more HP loss at PTO relative to a engine HP.
With autos we are led to believe more HP is better. With tractors that not necessarily the case.
   / Importance of Engine Displacement when Comparing SCUT/CUTS? #12
There are quite a few points to talk about here so i'll choose 1 to speak about displacement/horsepower.
Some people will tell you the days of large displacement is over and it doesn't matter, it's a little more complicated than that. Let's assume we are looking at engines with equal HP. More displacement is usually going to result in horsepower at a lower rpm and more torque at a lower rpm which will make the tractor feel much more powerful and allow it to more affectively use ground engaging implements and the loader. For PTO implements it's not going to change much.
The caveat here is forced induction(turbo), with the right sized turbo you can have a smaller displacement engine that makes the same or more horsepower without having to run very high rpms. This allows the smaller displacement machine to act a little more like its larger displacement competitor. The issue here is usually turbo lag which is basically the time it takes for the turbo to spool up and during this time engine power is underwhelming. This again gives an advantage to the Naturally Aspirated Larger Displacement engine, it has lots of power at a low rpm all the time and never has lag while waiting for a turbo to spool or doesn't need to wait for a small displacement engine to get the rpms way up high.
A quick example is my Kubota m5700(62 HP naturally aspirated) vs my cousins New Holland workmaster 70(70hp turbo charged).
My Kubota has a 168 cubic inch engine with 62 hp The NH has a 136 cubic inch engine with 70 hp turbo charged. Due to the turbo in the NH its actually rated at a lower rpm than the kubota but due to the smaller engine displacement and the turbo needing high rpms to really shine it kind of struggles at low rpm. When pulling a plow or running the loader the kubota actually feels more powerful and is easier to operate without bogging down since it has more torque at a lower rpm. Now once you are at MAX rpm the extra 8hp the NH has is noticeable if you are pulling a heavy disc or plowing a wet field or mowing tall grass. But for loader work, starts and stops, gear shifts etc the kubota is a little more "driveable and forgiving". Kinda splitting hairs here both machines run great and have plenty of power for their weight. But if you compare that workmaster 70 to a 70's vintage 70hp farm tractor the difference would be even more obvious.
Hope this makes some sense and isn't just a confusing mess or words.
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2016 KOMATSU PC240LC-11 EXCAVATOR (A60429)
2016 KOMATSU...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
