Not sure if metric or imperial bolts and nuts on the FX255D
   / Not sure if metric or imperial bolts and nuts on the FX255D #1
LeeSB
Yanmar FX255D
is the wheel nuts on a yanmar FX255D tractor wheels 14 mm or 1/2 inches
   / Not sure if metric or imperial bolts and nuts on the FX255D #2
Since most units come from offshore I strongly suspect metric.*
To make things confusing often loaders (and other accessories) are of local fabrication they could be SAE.
*if in doubt, take one wheel nut to the auto parts and they will confirm.
   / Not sure if metric or imperial bolts and nuts on the FX255D #3
The F255D uses 16mm bolts/studs on the rear and 14mm on the front.
Thank you! for your help!
That is as I expected, the guy working on my tractor was testing my sanity ;-)
   / Not sure if metric or imperial bolts and nuts on the FX255D #5
16mm rounds to 15.875mm aka 5/8-inch. :)
A 16mm socket will fit over a 5/8-inch bolt and loosen/tighten it. BUT, a 5/8-inch socket will not fit over a 16mm bolt. LOL crazy
   / Not sure if metric or imperial bolts and nuts on the FX255D #6
I believe he is asking about thread diameter and not bolt head size.
   / Not sure if metric or imperial bolts and nuts on the FX255D #7
I would bet money that unless someone has retapped certain holes there is not an SAE anywhere on that machine.
yes it is thread size, not bolt head size.
and yes the machine is all metric (I think) ;-)
The only thing that isn't metric is the tires.
Thanks to all for the help, one more thing does anyone know where I can get a copy of parts manual in English.
   / Not sure if metric or imperial bolts and nuts on the FX255D #9
For an FX....forget about it. The only thing you will understand is the actual part number.
I have one more question about bolts, would you have any idea what size bolts are used to hold the front-end loader on 'in mid-frame'
'in mid-frame' ; I can't upload a photo so I might be able to give a good enough description.
A couple of bolts along the side in middle at base of the frame of the tractor to attached some front-mounted lifting device blade or some such thing.
I do have electrical questions but I'll start a new thread for them.
2012 PJ Trailers PJFS25 25ft T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 PJ Trailers...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2015 CHEVROLET CRUZE (A56859)
2015 CHEVROLET...
New Holland 650 Hay Baler (A53317)
New Holland 650...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
