YM1700 and a 60 inch finish mower
   / YM1700 and a 60 inch finish mower #31
Start checking around for a Fuel cut off and Filter setup. It shouldn't be hard to find one. A YM 2000 is still the same setup I believe. The biggest problem to me for the way you have is Filtration. You want the fuel that's going to the Inj. Micro Thin in dirt and debris. Your see my point when you get a new correct one and see the Filter. Which is cheap and easy to find and replace. NAPA.. Start having problems with that Inj. Pump and then your talking $........ You have the same front wheel axle cap as I do. I think that's a Yanmar upgrade myself. Don't see it all that often. Go with the 60" mower. Rear Discharge is the way to go. It relieves a lot not having to get tall grass just out the side. And then you don't have a Dis charge line of cut grass either. Win Win trust me. The brothers new zero-turn he gets beat on it trying to keep up. But a really small residential lawn same Difference.
   / YM1700 and a 60 inch finish mower #32
We're fuel filter or fuel mentioned in this post? I am lost on your first part of your post Carey
   / YM1700 and a 60 inch finish mower #33
He's just a little slow:confused2: . Here figure it out, I guess I should have mention the FM. part of my post for first......
Can you take a picture of the factory set up. I knew mine is not Factory. Its on my list to get to.
   / YM1700 and a 60 inch finish mower #35
I do have one! You can see the filter and bowl. You don't want to have talk to the pumpguy unless you have to. Not much to it but a lot of "Piece of Mind".........
Where does a guy buy one
   / YM1700 and a 60 inch finish mower #38
Hoye,Fredrick's Should have them new. Hoye used even. It was the same setup on a few Yanmar Models. Don't know were your located but Spalding In Ga.. Steve may even have one I'm would think...
Does it look like the bracket is off mine also? That might be the difficult part to find
   / YM1700 and a 60 inch finish mower #40
See what I mean about the Filtration of it. What you have is asking for trouble........... It's for Gasoline.
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
Electric Concrete Mixer - (A51573)
Electric Concrete...
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
