How to straighten my boathouse?
   / How to straighten my boathouse? #101
Sheeting on the roof does two things. First, it gives you sheer strength. Second, it holds the nails used to attach the shingles. For sheer strength, OSB and Plywood are equal. For holding nails, OSB is significantly better. You have to by a high quality plywood to equal the low quality OSB sold at Home Depot to be equal, but if you are going to pay more for plywood, then Zip System OSB is going to be a much better choice. Nothing is better then Zip System!!!!
The problem with plywood is the voids and poor quality of each layer of wood. When you go into an attic an look at the sheeting from the underside, it's obvious how bad the plywood is by how much of it is blown out by the nails for the shingles. OSB is perfect around every single nail. And if you ever replace those shingle and nail over plywood a second time, expect the roof to fail a lot faster then the first time because of how damaged the plywood is.
Here in East Texas, 7/16 OSB is selling for $8 a sheet. It was $14 over the winter and sometimes it will get down to $6 a sheet. Half inch construction grade plywood is $18 right now and it rarely changes in price.
Leaving either outside and exposed to the elements will result in warping, delamination and failure. I'm not sure why anybody would be surprised at this. It's not designed for that.
Zip Systems looks like great stuff, but I looked at price at local Lowes for 7/16 and it was $30. and change per sheet right now. 1/2" tongue and groove is $33.60
I guess if you were paying carpenters to install, and it saved them time, which kept the job price nearly the same, I'd go for it.
https://www.lowes.com/pd/ZIP-System-1-2-CAT-PS2-10-Tongue-and-Groove-OSB-Sheathing-Application-as-4-x-8/50373850
   / How to straighten my boathouse? #102
Is steel roofing an option?
Roofers coming Thursday.
   / How to straighten my boathouse? #107
That's exciting. Thanks for the pictures. I'm amazed at what you've been able to accomplish!!!
Thank you, Eddie. It has indeed been quite an adventure, and it’s not over yet! Red eaves are next, perhaps as early a this week. Then maybe start on the painting of some of the (Red) trim. And I still have some work to do on straightening the walls.
OK, new roof is on, new red eaves are up. Painting and finishing the deck are next. And a bit more straightening.
Final wall colour will be "Mississippi Mud", to match one of the cottages, like this:
Anyone know how to rotate those first 2 pics? If you click on them, they are displayed in the right orientation - strange.
   / How to straighten my boathouse? #110
They show correctly when you click on them and open them up.
You致e done a great job. :thumbsup:
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
