3rd function kits....proportioning or not?
/ 3rd function kits....proportioning or not? #1
biggziff
Upstate NY
2015 Kioti CK4010HST
I'm utterly confused on the many 3rd function options for my Kioti CK4010. Diverters, true 3rd function, super true 3rd function, etc. MIE offers 2 3rd function kits that are listed as "true 3rd function", but one has the ability to feather the 3rd function controls vs just being on/off. I have that now in my ASV SR80 skid steer and I'm used to it, but it's another $400 or so with the MIE kit (LOADER TRUE THIRD FUNCTION KITS | miemachinerydivision). So, my question is...do you think having the ability to feather the 3rd function is worth spending the extra money? My intended use is a grapple, hydraulic angle plow for now.
I do have dual remotes on this machine also, but I don't want to have to run the remote lever to control the grapple or blade angle.
Other suggestions are also welcome. Trying to figure this out.
Thanks
/ 3rd function kits....proportioning or not? #2
I have a WR Long true third function on my tractor. It does not feather. It's either on or off. You get use to it. I certainly would not pay an extra $400 to have it feather.
/ 3rd function kits....proportioning or not? #3
The 3rd function valve is an electric valve that is on or off. So you push a button (typically on the joystick) and it controls the hydraulics.
A feathered 3rd function would allow you to control speed. Either with a manual valve (not convenient) or a fancier electric valve and switch that allows for fine adjustments.
I have an on/off third function and use a snow plow and grapple. Both work fine without the feather feature. If you needed some fine tuning on speed you can put a manual flow control on the grapple or plow- but I doubt you will need that.
The $400 extra cost would be for a select few who have a specific need to have the fine control. Maybe a hydraulic snow blower, mower or auger. With fine control you could adjust the distance the snow is blown or how fast the auger was spinning. Not something you really need on a CUT- they don’t have the hydraulics to run a lot of the hydraulic motors.
The diverter 3rd function is a simple electric valve that goes inline with the hydraulics that feed the bucket curl. When you hit the button you would divert flow from curl to third function by using the joystick. That would allow some feathering. But this option can be frustrating since you don’t have curl and 3rd function at the same time.
Thanks. I believe I understand how they all function and what the basic trade-offs are. The more I think about this, I don't think I need the proportioning and your post made me remember that I installed manual flow control valves on my big log grapple on the skidder to slow things down on that. Thanks for reminding me!
/ 3rd function kits....proportioning or not? #5
I was going to mention manual flow control valves, that would be the easiest way if you just need a fixed speed for something like a grapple.
Aaron Z
Aaron Z
Thanks!
/ 3rd function kits....proportioning or not? #7
I have a diverter for my grapple and it is just as easy to feather with that as it is to feather the FEL controls. The diverter switches the curl/dump circuit to the 3rd function while I hold the button down and then you use the FEL joystick in Curl and Dump to control the grapple lid open-close (or a plow angle). It is ALWAYS nice to have full control ...
I'm sure it's not big deal if that's what you've always had, but I don't want another button to depress to activate the 3rd function. I just want to be able to snap the attachment on and use the joystick without thinking about pushing a button to allow me to push another button for the grapple, etc.
/ 3rd function kits....proportioning or not? #9
The button is on top of the joystick, right where your thumb naturally goes. Zero effort.
Edit: You obviously should get whatever you prefer, which is up to you of course. I'm just noting that if you thought there was lots of extra effort or 3-hands coordination needed, that is not the case. It's super easy.
/ 3rd function kits....proportioning or not? #10
The diverter system like dstig 1 uses is the simplest to master. Hold button and curl joystick, grapple moves. Release button and curl joystick, grapple curls.
3rd function has two buttons joystick. One opens grapple. One closes grapple. Curl function is never interrupted. Speed of functions when used in triplicate varies depending on tractor gpm flow.
With diverter system the transition between grapple and curl can be seamless by quick button control
With 3rd function system the speed of grapple can be seamless by quick button control.
I prefer 3rd function. My tractor has the flow capacity to manage it well.
/ 3rd function kits....proportioning or not? #11
I'm running my dual lid grapple off a manual valve mounted on the fender near the loader joystick. I can feather the grapple but I've never wanted to. I hold the lever down until the material stops crunching.
A single lid with the same size cylinder would open/close twice as fast. That might want feathering at times but at least for me, probably not.
You could put in fixed or adjustable restrictors to slow the rate if needed.
Thanks, I've got some adjustable flow valves from my big skid steer that I'm going to plumb in and just go with a 3rd function kit. It'll be fine for my purposes.
/ 3rd function kits....proportioning or not? #13
I'd get the feather, you never know when you might need to pick up something you don't want to bend or destroy.. JMO..
It's $800 more than the 3rd function kits I'm considering. If you want to give me the extra, I'll do it.
/ 3rd function kits....proportioning or not? #15
You asked for opinions, if you can't afford what you're asking about,, DON"T ASK!:thumbdown:
/ 3rd function kits....proportioning or not? #16
Simply tap the button and be as gentle as you need.
Didn't say I can't afford it. Alluded it was foolish to spend that for the ability to feather. Sorry you didn't catch that.
/ 3rd function kits....proportioning or not? #18
Jeez dude. I'm with 1010. You asked for opinions, but now the ones you decided against are "foolish"?? Why bother asking?
ok
noted
/ 3rd function kits....proportioning or not? #20
I agree. Easiest and cheapest is diverter. Then as more features are added, cost climbs. If money is no object, go for 3rd function with control feature.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A59230)
2017 Freightliner...
