Brain Tumor
   / Brain Tumor #21
Better be okay because I just ordered a quick attach set of Pallet Forks.:thumbsup:
Now there is the right way of thinking! Be strong, you will do just fine! Where is the procedure being done?
   / Brain Tumor
Probably Providence Hospital. They also have the Cyberknife unit if I also need radiation. This has been kind of a cluster because no one knows what's going on. All the Drs need to get together without all of the receptionists. Just my opinion.
   / Brain Tumor #23
Best of luck and we’ll keep you in our prayers.
At my age, I opt for a younger Dr, i want one that hopefully will out live me.
That said, years ago, my wife’s orthopedics surgeon gave her this advice. If any Dr suggests he knows it all, doesn’t need more learning, RUN. Get the one always learning, questioning, relearning. Dr should be asking you questions and answering any yours.
   / Brain Tumor
Thanks. Good info from Mayo Clinic.
   / Brain Tumor
Thanks. Leaning in that direction also. I would think 10 years experience in neurosurgery would be enough. Most apt to be up to date in both knowledge and skill. Very highly regarded.
   / Brain Tumor #27
I realize location and type of tumor is different, although I wanted to mention approximately 15 years ago, a tumor was detected my wife's cerebellum and needed surgery a.s.a.p. due to the size of it was beginning to constrict the ventricle and drainage from her brain. A brief amount of therapy was needed for her balance after surgery.
100% success and continues to be healthy.
As noted, advancements in neurosurgery are amazing, and I am sure my wife's surgery may seem primitive compared to today's advancements just 15 years later.
   / Brain Tumor
Thanks for sharing. These reports of continuing success are very encouraging.
   / Brain Tumor #29
Prayers for you Doofy. I know it's scary but give it all to Him and He will take care of you.
   / Brain Tumor
Thanks for all the prayers. Every prayer helps.
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
