sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,264
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
I believe the original 20 series cabbed tractor could be ordered with A/C as an option. I don't believe it came standard with A/C. I did personally look at a new cabbed 20 series 2 years ago when I was tractor shopping at my dealer that did not have A/C (just had heat). I do think there are 20 series cabbed tractors running around now that do have A/C, but I am not positive.
I know that the cabbed 25 series comes standard with A/C (and heat), because I have one. There were a few other differences at the time, but I also think the "new" 20 series has an updated cab and all that may have changed now. I think they went back on the 20 series and put the "same" cab on it that the 25 series has, or at least copied the cab layout and features. As I believe the "new" 20 series cab has the bigger cab with more headroom that the 25 series came with when it hit the market 2 years ago.
I don't know why Branson has blurred the lines so much between the older 20 series tractors and the new 25 series tractors (with both still in production) , but it does get a bit confusing. I believe when the 25 series came out originally, it was intended to be a more feature rich model series than the 20 series. Then they went ahead and redesigned the cab on the 20 series anyway. The website doesn't do a very good job of answering these questions either. Hopefully your Branson dealer can shed more light on all this for you.
Yeah also weird how there is no 55 hp model in the 25 series and no 2.3 liter engine.
Thought I also read a post where it was said the 25 series had heavier subframe and also that the front axle was wider?
Another weird thing on the front axle is a mention of limited slip?
Further blurring lines both the BL25 and BL 200 FELs are available on both 20 and 25 series tractors. No explanation as to why the BL 25 would ever be a better choice either.
