Kubota L3901 vs New Holland Workmaster 40
   / Kubota L3901 vs New Holland Workmaster 40 #21
Unless you need the extra PTO HP for something, you could save a bit and go with the L3301, it has a better HP to weight ratio. If I had it to do over again I would have gotten the L2501, since I never needed a PTO implement.
A L3560 ROPS model is less than 3K more than the L3901 on Kubota's website(with 805 loader). That's a lot of additional tractor for the money, IMO. HST+ alone would make it worthwhile. Plus pinned swaybars, extending link ends, ratchet style leveler, greater 3PT lift, better seat, more weight, hip level fueling, bigger tires, wider stance, anti-stall, cruise control, autothrottle, better ergos, a much stronger loader...
As for the L3560 being heavy for the HP, I have the cabbed version and loaded tires. It does struggle some in medium high to go up hills. Medium low-no problem, even when pulling a full box blade. Which means your speed is limited to about 5mph uphill. I don't consider that to be that big a deal, but I also don't road the tractor anywhere.
   / Kubota L3901 vs New Holland Workmaster 40 #22
I'll disagree for the same reasons... I mow & road alot. Those need the HP. The L3200 (L3301) & L4060 are fine for traction work. They are ok for roading & mowing, but a few more HP is nicer, especially with hills & a wider mower.
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Payment Terms (MUST READ) (A50775)
Payment Terms...
