Kubota L3901 vs New Holland Workmaster 40
   / Kubota L3901 vs New Holland Workmaster 40 #21
Unless you need the extra PTO HP for something, you could save a bit and go with the L3301, it has a better HP to weight ratio. If I had it to do over again I would have gotten the L2501, since I never needed a PTO implement.
A L3560 ROPS model is less than 3K more than the L3901 on Kubota's website(with 805 loader). That's a lot of additional tractor for the money, IMO. HST+ alone would make it worthwhile. Plus pinned swaybars, extending link ends, ratchet style leveler, greater 3PT lift, better seat, more weight, hip level fueling, bigger tires, wider stance, anti-stall, cruise control, autothrottle, better ergos, a much stronger loader...
As for the L3560 being heavy for the HP, I have the cabbed version and loaded tires. It does struggle some in medium high to go up hills. Medium low-no problem, even when pulling a full box blade. Which means your speed is limited to about 5mph uphill. I don't consider that to be that big a deal, but I also don't road the tractor anywhere.
   / Kubota L3901 vs New Holland Workmaster 40 #22
I'll disagree for the same reasons... I mow & road alot. Those need the HP. The L3200 (L3301) & L4060 are fine for traction work. They are ok for roading & mowing, but a few more HP is nicer, especially with hills & a wider mower.
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
