   / Share Pics of People Hauling or Towing Something Wrong #10,661
Thats funny!
My last truck purchase, the salesman walked me out to the truck after signing all the appropriate documents, and I stopped and opened the tailgate, as he watched, you could see a bit of confusion coming over his face.
I reached into my pocket and took out my keys and drug the sharpest one across the tailgate.
He looked at me and said.....
"Might as well get it over with huh?"
   / Share Pics of People Hauling or Towing Something Wrong #10,662
Is my trailer overloaded?? :eek: That is limestone rock.
   / Share Pics of People Hauling or Towing Something Wrong #10,663
^^^ We need to see your hitch, tire pressure, brake conditions, how far you will travel, what degrees of hill travel plus general maintenance records to be sure :D
   / Share Pics of People Hauling or Towing Something Wrong #10,664
   / Share Pics of People Hauling or Towing Something Wrong #10,665
The hitch is 1 7/8" ball, but no secure pin is used,, :confused2:
Trailer tire pressure is ~25 PSI, checked annually,,, the tractor tires are original 1984,, with only 11 PSI.
any more than 11 PSI causes the sidewall cracking to open up too much,,,:eek:
No trailer brakes, only 1984 original tractor brakes, but, I use the "Yanmar" engine brake going down grades, usually in 4WD so the rear tires do not spin,,
Travel distance is about 1/4 mile, loaded, 1/4 mile empty,,,
The degrees of the hill I go down is so steep, out of 162 eighteen wheelers that came up to haul wood, not one made it up the hill without the skidder pushing it.
The only maintenance record is the hours and date that I scratch with a pocket knife into the end of the oil filter,,,
Heck, the oil change is the only maintenance I have ever done,,,:ashamed:
It looks like you have a tree growing out of your exhaust stack..... ;)
I will take a chain saw out and cut that tree today,, I do not want it to block the tractors exhaust!! :D
   / Share Pics of People Hauling or Towing Something Wrong #10,668
Here痴 one I stopped for what should be obvious violations.
How many can you spot?
   / Share Pics of People Hauling or Towing Something Wrong #10,669
OH MY! I think I saw 7 obvious ones without checking tire pressures and tread depths. I imagine this was an immediate OUT OF SERVICE and tow?
   / Share Pics of People Hauling or Towing Something Wrong #10,670
I didn稚 see trailer plates, maybe they are outside any of the pics
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
