My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower #231
Other than break-in : idk why anybody would want to mow less that Wide Open Throttle (WOT)
Coming from almost 60 years in the gas engine world I've had to adjust to the full throttle diesel mowers world for the last 12 to 15 years. The ZD is 40+ hours now so close enough for me to now do wide open throttle ito get the grass cutting results I want and expect from Kubota mower.
   / My New Kubota ZD1211 Mower #235
I always mow out, turn around & come back.
Never in circles.
After removing rear rubber flaps from RD deck & mowing weekly :
I’ve discovered mowing 90 degrees to the previous week helps windrowing a little bit.
I mow North & South one week then East & West the next.
In my bigger open areas, I have mowed at 45* in between weeks too here & there.
I don’t like the dead grass windrows from Heavy Thick Grass But I Love my ZD1211-72RD Machine :D
   / My New Kubota ZD1211 Mower #236
Never in circles.
I to deviate my mowing pattern. I do across my yard and then from street to house and then diagonal from mailbox on front corner to burn pile toward opposite corner and then from drive way toward neighbors corner of his driveway. My grands on now helps and he wants to always do street to house so I have to jump on one mower and start the pattern for the mowing session and then get him sucked in to my pattern and I quit.:D I do around 3 precious to me 3 pre bearing pecan trees and sometimes the circle just goes out and out and out and out till I have a big circle and then I'm at the other pecan tree and start my circle and keep it up till I reach the beginning of my next circle and just drives my wife and grandson crazy when they see my three big circles. Got many trees but usually, usually I say only do the circle cut on the pecans, my precious pecans.:cool2:
My grand loved the F over the BX and I think he still does butttttt he may have a slight preferencefor the ZD over the F, he hesitates when I ask his preference. At a 14 year old wanting to drive boy the spinning ZD is quite an attraction and they both ride good so guess BX mowing is history for sure.
   / My New Kubota ZD1211 Mower #237
:D..........No, I just got the F and ZD and RTVx1140 this year, the ZD was used with 37 hours, so no not this year any more trading. This may be my last trading bout...........:D:laughing:
Is that even possible? 😀😀😀 Thanks for keeping us up to date on Kubotas of all kinds!
   / My New Kubota ZD1211 Mower #238
" All you do is get a set of holders K5955-34380 and cut the ends down to 1.120" and buy whatever blade you want to use. Plenty available. "
I'm planning on doing this shortly on my 72" side discharge. Still looking for the best blade.
   / My New Kubota ZD1211 Mower #239
Oil filter rubs against lower radiator hose.
Hose is wearing thin.
   / My New Kubota ZD1211 Mower #240
I checked my radiator hose. It clears the oil filtHer.
Would the Oregon G6 Mulching Gator Blades sling grass out a SD Deck OK if blade holders was converted to accept the smaller center hole RD blades ?
Also, are the RD & SD blades exactly the same length from tip to tip ?
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2018 Chevy Traverse 3rd Row Seating (A56438)
2018 Chevy...
Friesen 240 Seed Tender (A59814)
Friesen 240 Seed...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56438)
Bulk Lot of over...
Wolverine Quick Attach Post Hole Digger w/ Augers (A59814)
Wolverine Quick...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
