My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower #221
The SD Pilot did get covered with clippings.
I hate being limited to one direction with SD to keep clippings off of buildings & out of the road.
All of My Dang neighbors blow their clippings into the road : Burns Me Up !!!
You never realize how much being able cut on both sides of the mower reduces your mowing time, until you get a RD. I have my mower making beautiful stripes too, but I do cut at 4"
   / My New Kubota ZD1211 Mower #222
Yes sir I agree on RD : I Love mine :D
I’d buy a second ZD1211-72 SD IF I hadn’t just bought a new 15’ BH 2815 Cutter.
I mow Tons of Grass weekly here around the farm to keep varmits away.
   / My New Kubota ZD1211 Mower #223
I hope you are not planning to attack any of them like............
:eek:
Oh no lol
I don’t take it as serious as the guy 20 miles South of me did a few years ago when He burnt his neighbors house down, for not keeping their yard mowed.
   / My New Kubota ZD1211 Mower #224
Holy H$LL... That is one expensive rotary cutter. Congrats
   / My New Kubota ZD1211 Mower #225
My 3pt Lift Type JD MX10 was taking way too long.
I kept it tho to mow a steep 700’ long bank & using the 2815 on the open fields.
It’s a Beast :D
   / My New Kubota ZD1211 Mower #227
I don’t wanna hi jack the ZD thread lol
I’ve got a separate 2815 thread with baffle option pix tho
   / My New Kubota ZD1211 Mower #228
Did you remove the rubber flaps and trim the center trans shield? Are you running Gator blades?
Not until I do a test run with for sure full throttle today.
   / My New Kubota ZD1211 Mower #229
:cool2::cool2::cool2: Discovered the problem with the windrowing of the ZD1211 RD and fixed it. Mowed grass for a bit that was to high and to wet. Waited an hour or so and mowed grass that was still to high but not wet. My grandson and I were using the F and the ZD and switched out and after mowing, no windrows and then after waiting a day still no windrows showing and then another day the grass is spread perfect on the yard!!!!! FULL THROTTLE on the ZD and about 90% on the F since it is under 10 hours use on it and when closer to 50 hours will bump it up to full. Have to go a little slower on the F with high grass and mulching kit and not doing full throttle but it spreads the clippings great. Entire yard looks wonderful today!!!!:cool2::cool2::cool2: FULL THROTTLE IS THE ANSWER and still with rubber across back and original blades, pure stock Kubota machine and deck, just full throttle solved the issue. Also grandson doesn't drive either one slow! :)
   / My New Kubota ZD1211 Mower #230
Other than break-in : idk why anybody would want to mow less that Wide Open Throttle (WOT)
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A58376)
UNUSED WOLVERINE...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
Mini Excavator Hydraulic Thumb (A55272)
Mini Excavator...
UNUSED FUTURE QST HYD MINI SWEEPER MINI SKID STER (A58376)
UNUSED FUTURE QST...
2018 Ford F-150 4x4 Extended Cab Pickup Truck (A56858)
2018 Ford F-150...
