GC1720 and king cutter hog size
   / GC1720 and king cutter hog size
I have not seen the chain setup. Do you adjust the top link shorter and simply put a chain around the end and the top of the cutter connection?
   / GC1720 and king cutter hog size #22
You remove the top link and replace it with a length of chain
So adjustment is limited or not at all. Any drawbacks?
   / GC1720 and king cutter hog size #24
Drawback is using too much chain and finding a dip where it the back of the cutter going up and the chain wraps around your PTO shaft
Edit: added picture for referenceView attachment 620124
   / GC1720 and king cutter hog size #25
I wouldn't be able to use a 5 footer on the JD 2025R even though it has the hp (5 hp/ft) for it. The sides of the cutter would hang out past the rear wheels for about 6" on both sides. I'd be forever hanging it up on those front corners on the trails and other tight spots that I have to mow.
Had a 4 footer on the 18.5 hp JD 4010. Did fine with it but same issue to use a wider one, and it does not have the hp for a 5 footer.
Ralph
I do have some hilly terrain
2025 Swict 66in Bucket Skid Steer Attachment (A55851)
2025 Swict 66in...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2015 Toro Reelmaster 3 Gang Mower (A55851)
2015 Toro...
Husqvarna Z 248F 48in Zero Turn Commercial Mower (A55851)
Husqvarna Z 248F...
UNUSED SDLANCH SDLC2020 - 20' X 20' CARPORT (A57193)
UNUSED SDLANCH...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
