I declared war on Johnson grass
   / I declared war on Johnson grass #1
Granthol
Republic, mo
Branson 2910i
The Johnson grass was here when I bought the land and not surprisingly it痴 spreading. I didn稚 want to do an all over spray since there is great red clover and orchard grass everywhere else. So today I hooked up the wick applicator I bought online, loaded it with glycophosphate and water 1-1 and started wiping weeds. I値l know how effective it was in about a week. Guess we値l see.
   / I declared war on Johnson grass #2
That is interesting. Please give us a pic of the result and your evaluation. I've never tried that set up.
Cheers,
Mike
   / I declared war on Johnson grass #4
I've got one of those and the farmer I bought it from swore by it. Guess I never got the hang of it. so I walked it all down with a 4 gal. sprayer.
But do have about 1/4 acre of it left. So here is my plan: using the Pat's hitch will use the two hitch points to hold the pvc and then able to lower the wicks closer to the root and crawl through the grass slowly. Hopefully give them a good soaking.
May not have gone slow enough the first few times I tried.
By all means let us know how the kill rate works for you.
I need the encouragement...!
Looking at your pics a bit closer noticed you used the same large hose clamps I did. Now I'm thinking the secret is to prevent the pvc pipe from rolling with the grass and reducing the contact patch between the grass and the wicks.
So now will have to find a way to secure the pipe to the rear hitch points and prevent it from rolling.
   / I declared war on Johnson grass #5
Used properly, they work great.
Once the ropes are saturated, keep the wicks just above the desirable vegetation.
Proceed at an average walking pace. (Roughly 5 mph).
Post results please. Thanks.
   / I declared war on Johnson grass #6
After a closer look and some thinking.
The one we had, about 40 years ago, was on an M Farmall Front mounted with a cylinder to raise and lower.
It was 12' wide. That made watching the height much easier as i moved across the cotton fields.
Possibly had a bit stronger product back then. Round-up was fairly new on the market.
   / I declared war on Johnson grass #7
I don't know what Johnson grass is..but if it's anything like bent grass that we have here, it sucks.. I just bombed my yard with Tenasity about a month ago, and touched up a few spots that I missed the first go around, it's it's almost all wiped out ..another hit or two in the spring and my lawn should be spectacular
   / I declared war on Johnson grass #8
In the old days, the farmer would turn the hogs in on the Johnson grass, providing it was fenced. They will root the stuff out, roots and all, and kill it completely out.
   / I declared war on Johnson grass #9
Tom, I started my lawn rehab 2 weeks ago. I have lots of weeds and crabgrass. I fertilized to make the grass strong, plug aerated, and reseeded. I will use a weed & Feed in the spring.
   / I declared war on Johnson grass #10
If you have not seen the herbicide Tenacity yet.... look it up on YouTube ...kills crabgrass post and pre emergent..without killing new grass or seed... stuff is magic...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
Bell B30E (A50123)
Bell B30E (A50123)
(7) UNUSED IRANCH PORTABLE DUMP HOPPERS (A54757)
(7) UNUSED IRANCH...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
