How to remove PTO shaft from slip clutch on rotary cutter?
   / How to remove PTO shaft from slip clutch on rotary cutter? #11
Not long enough at current stuck length to connect to tractor PTO. Guess I could connect it to a clevis on the drawbar
Just what I had in mind.
Chain the cutter to a tree & chain the tractor end of the shaft to the tractor tow bar or the back of your pick up.
Once you have the shaft seperated, you can clean it up & it will last for the rest of YOUR life.
Got the end that connects to the slip clutch pushed forward. That lip that prevents it from being removed does not want to budge and looks like its a part of the clutch not a ring that can be popped off
   / How to remove PTO shaft from slip clutch on rotary cutter? #13
....then why is there a grease fitting?
Edit#1: Ahh.....so when the sheer bolt break it spins.
Edit#2: Did you get the clip off that can be seen in other photos? That clip must have a purpose.
   / How to remove PTO shaft from slip clutch on rotary cutter? #14
Have you tried massive amounts of penetrating oil, apply tension, and Tap Tap Tap?
   / How to remove PTO shaft from slip clutch on rotary cutter? #15
Inspect the ring, all the way around it, looking for a seam. It looks like a snap ring to me.
Soaked it down with WD 40. Used a large flat head screwdriver and a sledge to tap it. Should it be moving towards the slip clutch or away from it?
Just got some penetrating oil from tractor supply so going to hit it with that
   / How to remove PTO shaft from slip clutch on rotary cutter? #17
When I bought my PHD the shaft was seized. Sprayed it with PB Blaster and tapped (or beat, whatever you want to call it) with a sledge hammer every day for about two weeks. It finally came apart. I keep it inside now so that I don't have that issue.
   / How to remove PTO shaft from slip clutch on rotary cutter? #18
Soldier, the ring won't slide. It's snapped into a groove that's cut into the shaft, so you need to snap it out of the groove. First find the seam or gap in that ring. You'll need to pry one end out of the groove and work it around and out. Some snap rings have a hole in each end of the ring and are meant to be spread and removed with snap ring pliers. There's a snap ring in your picture, to the left of the one you're working on, inside the yoke. That ring is in the yoke (internal) rather than snapped on the shaft (external).
   / How to remove PTO shaft from slip clutch on rotary cutter? #19
Design factors dictate the "ring" is to retain the "U" joint yoke.... Ring has to be removable by design... You are just not seeing way to release ring....
Dale
   / How to remove PTO shaft from slip clutch on rotary cutter? #20
Find the split in the ring: It has to have one. Then work it with a small chisel and shop hammer to pound it out of the groove. Work both ends till it frees up. A lot of penetrating fluid as you work the split ring from both ends. It is likely rusted in place but it will come out with some pounding on the chisel. You may need to apply some heat to it if the chisel isn't doing the job.
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
CANOE (A56859)
CANOE (A56859)
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
