gc2300 no hydraulics.. ball bearing
   / gc2300 no hydraulics.. ball bearing #21
they are the same just wanted you to see the wear on old shaft end to new one
the bearing still on old shaft i replaced it
I guess it scales differently because the bearing on the old shaft holds it up closer to the camera? Sure fooled me.
   / gc2300 no hydraulics.. ball bearing #22
Yes, many digital cameras are notorious for getting a "fish eye" effect (distortion) with close-ups. That's why I asked... I've seen it before. Sometimes useful to include a ruler in pics.
earndale, I feel your pain... and you're braver than I! I had a bad weld on my 4WD shift fork, which broke off with only about 500 hrs on my GC2310. There was an obvious lack of heat penetration on it. (GRRRR!!)
I didn't dare tear the whole thing apart, even though the shift fork was in the tranny cover; the whole tractor had to be torn down and the tranny removed & rotated before removing the cover, to keep all the shafts & bearings in place -- which I'm sure you've discovered.
So it cost me about $1200 to replace a $35 part... Seems I saw that ball & spring in there, too -- it's used for detents on the 4WD shift lever, IIRC.
Good luck with your "minor" repair! (Hope my shaft holds up....)
PS-- what year is your 2300? (Mine's a 2007, one of the last ones.)
I think 2007 also.. was my brothers gave to my dad.. I am the mechanic..found that the hour meter is broke... says 480 hrs I write on filter date and hours … which was whe I changed hyd pump..spur gear... lol 2012
go figure so do not know actual hours.. but will fix this weekend... sad not good upkeep... I am in the middle of 84 year old man,, lol will let you know on start up this weekend,,,,..
ok good news..all together all hyd. works good yes!!!! sad that one spline shaft runs all gears in trans housing.. poor design... but what can you do spend $15k 10 plus years ago..
but all works good for now lol ….any details you might ask I think I can help....2 times taking apart
   / gc2300 no hydraulics.. ball bearing #26
So, aside from the fact that it's a lot of work to remove the rear end, how would you rate the degree of difficulty to do this replacement on the 10 scale?
Were there any specialty tools required to accomplish this?
   / gc2300 no hydraulics.. ball bearing #27
Probably just metric tools instead of standard
no special tools metric wrenches lots of patience,, as for me i rate it as 5-6 level very time consuming take pictures if going be apart for awhile
i am a mechanic by trade...
   / gc2300 no hydraulics.. ball bearing #29
Thanks. I am fairly sure this is in my future. And, though I have 40+ years in the auto repair business, It's mostly body repair.
I don't mind a challenge. And, I don't mind even going as far as doing a timing chain, heater core, or even pulling a complicated intake manifold on a late model engine. But, I have always drawn the line at engine, and transmission overhauls. So, I'm not too sure if I want to try and do this myself.
I also hate relying on anyone else to do something. :confused3:
   / gc2300 no hydraulics.. ball bearing #30
...And there's the conundrum, Ray.
I'm in the same boat as you, as far as experience; went through the service manual umpteen times, visualizing the process in my sleep.... but in the end I chickened out and had a local guy who works on tractors for a living do the job. He went through a fair bit of headaches, too, but he got it done.
Still aggravates me that it was a poor weld from the factory to begin with and cost that much to replace such a small part. I'm sure some of these pics will look familiar to earndale. Oh, yeah -- there's his ball bearing, #6 in the 3rd pic.
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2014 International Maxxforce DT (A53317)
2014 International...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
REYNOLDS 14C SCRAPER (A58216)
REYNOLDS 14C...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
7ft Workbench (A57454)
