Check to see that all the other instruments and dash lights are working properly. If so, then your tach is driven NOT by a cable from the engine, BUT by a wire from the alternator. Should be a green wire off of a terminal on the alternator that goes to a connection on the back side of the dash panel. You should disconnect the ground cable from the battery, if you mess with the alternator wiring. It may be as simple as the cold making the needle stick and an appropriate bump to the bottom of the dash may loosen it up. Good luck.
Thanks! I will check it out.
Steve
I attached a couple of photos of the back of my alternator, hopefully adequate enough to give you an idea where the green wire plugs into it. Yours may be the case that the alternator has been replaced with a generic unit with no tach provision. Check to see if the mounting bolts have been removed or unthreaded. The wiring diagram is color coded in that the letter at the end of the description denotes the color.View attachment 623562View attachment 623565
And welcome to TBN
You don't know how relieved I am to receive your response. Thanks!!!
Now I know exactly what my problem is which will save me a lot of time and possibly unnecessary parts purchasing.
My alternator looks like yours and others that I have seen pictures of on the internet--but cannot really see the area where the green wire is attached on yours since I have a bracket in the way along with having the arm from the front end loader in the way.
As soon as I finish my morning coffee I will remove the bracket that is in the way--looks like a simple job and see if I have the correct alternator and if so determine why the blade connecter/wire was disconnected. I suspect that I have a generic unit with no tach provision-but will soon find out.
I earlier noticed that there are several alternators advertised on the internet as being "exact replacements" but guess I need to find out if they are really exact before I buy one if the wrong alternator is my problem.
Thanks again, my next challenge is to find out (curious) the manufacture year of the tractor and assume there is some way to find that out via the vin number.
Gerald
