Imold
- Joined
- Jul 23, 2019
- Messages
- 816
- Location
- West Central Mn.
- Tractor
- MF GC1705, Cub Cadet RZTL, Husqvarna Rider.
If you want to warm oil up, you can do it more effectively with a silicone pad heater permanently glued to the bottom of the oil pan. And, they are not expensive.
You do have to be careful not to use a heater that is big enough to cook the oil.
I use a 140w pad heater on my transmission to keep the oil from getting cold soaked.
That is a valid point about having to much wattage.
Folks used to use the pad heater or magnetic heater with their older vehicles around here but now most of the vehicles up here have frost plug heaters but as far as tractors go they are still somewhat popular, every once in a while you will see a magnetic heater laying on the road just because they decided to let go or the vehicle hit a major bump or low spot in the road, dip stick heaters are kinda of a popular item with folks to.
I have seen diesel pickups with 3 to 5 plugins sticking out of the grill, they have frost plug heater, battery blanket heaters, trans heater pad and some even have the dipstick heater, yep they want their diesel to start no matter how cold it gets just to have them gel up on the highway at 55 because they wanted to save 5 cents a gal on fuel.(just a funny but somewhat true).
I have known guys who have used heat lamps under their hoods or under the vehicle and then cover them up with a tarp to try to warm the engine block up, my ex father in law used to put a coffee can of mixed oil, diesel under his Farmall in the garage and light it then set it under the engine block and then sit back and drink coffee while it warmed up the block, people do all kinds of things to make sure their vehicles starts.
