Kubota GR2120 diesel - 2016 Cab fabrication
   / Kubota GR2120 diesel - 2016 Cab fabrication #31
Anyway said:
I got the blower winter of 2013/2014, knew right away I needed something better to cast light ahead of the work. So, I installed that single LED light fall of 2014 for the 2014/2015 winter season, so that makes 4 years of use without issue. I think the vibrations up there are pretty low frequency, so that probably helps with operational life. It is a simple hook up, I just tied into the tractor light wiring with a spade connector. Philip.
   / Kubota GR2120 diesel - 2016 Cab fabrication #32
I got the blower winter of 2013/2014, knew right away I needed something better to cast light ahead of the work. Philip.
Appreciate the response - vibration would certainly be low frequency indeed - I have a magnetic mount I am going to be trialling for a rearward-facing work light. Tks
   / Kubota GR2120 diesel - 2016 Cab fabrication #33
What kind of wood did you use and is it weatherproof or did you just use a sealer?
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
2018 FORD EXPEDITION (A51406)
2018 FORD...
