Diesel in winter
   / Diesel in winter #21
You will only freeze up once and thereafter always be adding your own additive at every tanking, believe me.
When your tractor stumbles and burp and your fuel bowl looks like mushy icecream its too late.
That's coagulated wax and it can't be pumped by the injector pump.
Only cure is heat at that point.
+1 on that. I use Powerservice year around.
been there, did that with coagulated diesel fuel.
   / Diesel in winter #22
".... You will only freeze up once and thereafter always be adding your own additive at every tanking, believe me."- PILOON
It happened to me twice. The first time was the first winter after MA mandated that all on road diesel be ULSD in 2006. A lot of heavy equipment machine operators, trucking services, and most school buses got gelled up with the first real cold snap. The second was this Spring after a Winter of non-use due to personal injury. It will not let it happen again if I can help it.
   / Diesel in winter #23
My dealer warned me of this when I bought mine years ago. They had a truck load of tractors delivered from Wisconsin mid winter, and they all had gelled fuel. He told me the horror stories of how hard it was to get the fuel systems cleared just to get them unloaded. I've used Power Service, but now use Howes Diesel Treat year round (double dose in winter).
   / Diesel in winter #24
   / Diesel in winter #25
ruff dog- Thanks for the links
A few of the local diesel users here way back I 2006/2007 switched to biodiesel fuels and had all kinds of problems associated with biodiesel "lifting" old tank crud and had problems with their fuel lines. I copied this from the internet:
"Another problem is biodiesel's behavior as a solvent. Though this property is helpful, it's kind of a double-edged sword. Some older diesel vehicles (such as cars made before 1992) may experience clogging with higher concentrations of biodiesel. Because of its ability to loosen deposits built up in the engine (which may be there from old diesel fuel), biodiesel can cause the fuel filter to become jammed with the newly freed deposits. Biodiesel manufacturers suggest changing the fuel pump shortly after switching to high-concentration biodiesel blends. Components within these older fuel systems may also become degraded. In addition to deposits within the fuel system, biodiesel also breaks down rubber components. Some parts in the older systems, such as fuel lines and fuel pump seals, may become broken down due to their rubber or rubber-like composition. This is usually remedied by replacing such components. Though many manufacturers have included biodiesel in their warranties, potential for problems could still exist. For more information on biodiesel and vehicle warranties, check out The Biodiesel Standard."- internet source.
   / Diesel in winter #26
Quote---"Biodiesel manufacturers suggest changing the fuel pump shortly after switching "
Otherwise known as CYA. (cover your a--)
And at what price? fuel pumps (add labor) don't usually come cheap.
Where are the savings?
Best yet is use a well known fuel and an additive come cold weather.
   / Diesel in winter #27
I'll add more to this trend.
I also heated with oil, come January and a low tank the heating oil would not flow even tho I used 1/2" copper.
I added a heated 'tracing line' to cure that problem but the oil dealer suggested that I switch to 'winter fuel' which he described as carosine (lamp oil) but at what price?
Never mind, no tractor fuel at my house will ever be untreated, that I promise you.
   / Diesel in winter #29
   / Diesel in winter #30
I didn't hear what the mix ratio was that he used, The white bottle Power Serve does call for double the normal dose for that temperature.
Also, the 911 doesn't prevent gelling it is supposed to cut a channel thru the gelled fuel and lines and filter to get you started and back to a warm shop.
Carnival Ticket Booth (A51691)
Carnival Ticket...
(APPROX. 20) 4' X...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
