ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,428
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
They may only start to change the blend 2 days before the forecasted low? So if you bought your fuel 3 days ago or more you’re S.O.O.L? Well that’s helpful. Not.
Yes, this is how I understand it's done now. It's a gradual increase in mix, just a couple days prior to low temps, and they re-adjust back if warmer temps are in forecast. This is done for what diesel is mainly used for, which is trucks not tractors. It's not done at a certain date and mixed for maximum cold all winter. The dates they show are to indicate the window that they monitor cold temps and mix accordingly, one day at a time. They figure most fuel is used within a few days of when it's bought.
After reading this thread, adding my own additives is what I will do. They are not expensive and I doubt I will use more than 50 gallons of diesel blowing snow and moving firewood during the winter. Temperatures can drop to -35*F but that has only happened once in the 6 winters I have spent here. At that temperature I would not be using the tractor but fuel will still gel. When it happened, I had a diesel truck and it died 1.5 miles from home...gelled fuel. Royal PITA.
I will double does both the PS white bottle and Clear Diesel Fuel and Tank Cleaner. Going to get some Diesel 911 as well. Better safe than sorry.
