Dumping aDump Trailer with a WD Hitch Attached
   / Dumping aDump Trailer with a WD Hitch Attached #11
That was my assumption. Most people ignore those warnings. Good on you for following the recommendation.
   / Dumping aDump Trailer with a WD Hitch Attached #12
What is even worse it the people that think they can just replace the factory hitch that required a WD for over 5-600 pound TW with say a 15000# rated hitch that doesn't require a WD and think they are good. I am also wondering how they get around the WD system on the newer pickups that claim no WD required even towing 15000#. How did they get it set up so it doesn't unload the front axle.
   / Dumping aDump Trailer with a WD Hitch Attached #13
You don’t need to do anything in order to dump you trailer. Leave the bars attached.
   / Dumping aDump Trailer with a WD Hitch Attached #14
Toungue weight is dif that total trailer weight. Load your trailer correctly and you wont need a WD hitch.
   / Dumping aDump Trailer with a WD Hitch Attached #15
The verbiage on my old truck was that a WD hitch was required when tongue weight was 500 pounds or the total trailer weight was 5,000 pounds, or over.
   / Dumping aDump Trailer with a WD Hitch Attached #16
Well....that is actually not correct.
The OP has a loaded trailer maximum weight of 6500 lbs.
It is commonly known that tongue weight should be 9-15% of the gross.
He therefore needs a minimum of 585 lbs. tongue weight, but his manual states that a WD hitch is required over 500 lbs. tongue weight.
What would I do?
I would try to keep the cargo weight at 3,500-4000 lbs. whenever possible and skip the WD hitch.
BTW: I have a 14K equipment trailer that when heavily loaded, I use with an Equal-i-zer hitch, and the hitch does make a BIG safety difference!
   / Dumping aDump Trailer with a WD Hitch Attached #17
Agreed. The only thing I that I do to dump or after dumping is reduce the trailer brake gain due to the lighter load. The only reason I would remove the bars is if you are traveling on bumpy roads. On mine the empty dump trailer seems to bounce a bit more with them on, but it is typically not an issue in my travels so I leave them on. And anything less than filling the dump trailer to it's weight capacity is just wasting time, trips, and fuel if you have multiple loads.
New/Unused Single Portable Toilet (A57453)
New/Unused Single...
2016 INTERNATIONAL DURASTAR 4400 (A58214)
2016 INTERNATIONAL...
2021 KOMATSU PC88MR-10 EXCAVATOR (A52709)
2021 KOMATSU...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
2001 Ford F-550 Liftmoore 6036 3 Ton Crane Service Truck (A56858)
2001 Ford F-550...
