Hey TM, good to see ya
I just don't get the following, but still do truly enjoy the reading of statements.
If there is water in the fuel use some Alcohol to help soak it up. It might help, it might not.
Have no idea why a gas motor needs oil in the fuel unless its a 2 cycle motor. How is a small amount of oil going to lube anything, for me I don't get it.
In a diesel motor adding oil to diesel (which is oil) don't see that doing any thing either.
Why put alcohol in diesel, the last thing you want is water going into the combustion chamber
Naphtha is flammable, its basically a cleaner and lighter fluid. I can see Nap cleaning things, but then again, don't see it as a good thing in a diesel motor. Ever put gas in a diesel, it turns into a 4000 pound paper weight (I've done it). Nap is not a lubricant so if it gets to high then damage to injectors can happen.
While folks say it works great and I respect pumpguync, but still if it needs to be cleaned, then remove and clean it.
