MechanicalGuy
Okay, I am putting in a hydraulic top link and I will be mainly using the rear of the tractor for bush hogging and box blading. I put a hydraulic remote in place when I bought the tractor new because it would give me options. I didn't specifically ask for a spring centered valve, but it seems like that would be optimal for feather adjusting my top link for box blading. Right now my plan is to get a needle flow control valve and put it in line with a #8 hose set. My cylinder is gonna be a 2.5" bore 12" stroke unit. Right now my valve is not spring centered. I know that hydraulics should typically be metered in, vs pneumatics being metered out. If I don't put a flow control in will I have fine enough control over the top link to make very minute adjustments in the blade angle? Is it more advantageous to have a spring centered valve?
Can I get by with just a single flow control on one line? Or will both lines need a flow control? I was looking at the free flow in one direction and metered in another direction type of flow control.
Tell me what I might not be considering. I'm familiar with hydraulics, but not tractor hydraulics.
Thanks for the input.
