Capless fuel tanks... is the idea as dumb as it seems?
   / Capless fuel tanks... is the idea as dumb as it seems? #101
I guess time will tell. So far it doesn't seem to be the actuator or it's internal circuit board, or I can't imagine it just starting to work again.
   / Capless fuel tanks... is the idea as dumb as it seems? #102
Back when Ohio had emissions test, defective fuel cap was a leading cause of test failure. Loose fuel cap on ground near gas station was common also
   / Capless fuel tanks... is the idea as dumb as it seems? #103
If it痴 a GMC it will probably start working on the first warm sunny day you get!
   / Capless fuel tanks... is the idea as dumb as it seems? #104
I believe it was Henry Ford who said not to worry about automobiles putting buggies and carriages out of businesses not 1 person in 100 would be able to learn to drive them.
You'll have to provide a source for that quote. I think you're mis-attributing the quote to Ford, who would never say anything that ludicrous about automobiles. I have four biographies of Ford and the quote does not appear in any biography. It also does not appear in any Internet searches of "Ford quotes," or "Quote of Henry Ford."
Do you really think that a man who devoted his life, from an early age, to the development of the automobile would say "not to worry about automobiles putting buggies and carriages out of business"? I find that hard to believe as it is so un-Ford like in its sentiment. So please, provide a source, other than what you believe or your memory of reading something somewhere, as I'd like to know the source that directly ties the quote to Ford.
   / Capless fuel tanks... is the idea as dumb as it seems? #105
Both my F150's are capless. No issues so far.
I freaked at first because of no twisty cap on our 2010 F-150 but there has been no fuel problems for two years so I guess it works. I have never left it off and took off. :)
   / Capless fuel tanks... is the idea as dumb as it seems? #106
We have 5000 miles on our 2019 ranger and we've liked the "cap" so far.
   / Capless fuel tanks... is the idea as dumb as it seems? #107
I have no problem with capless on my pu, and I live on a gravel road...
SR
5' PULVERIZER, 3PT (A52708)
5' PULVERIZER, 3PT...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Tandem Axle, 7 Gage Steel Floor, Power (A59076)
2022 Diamond T 14'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Timpte Hopper Bottom (A56438)
2014 Timpte Hopper...
