Fisher plow P/T fuse blows - sometimes ??
   / Fisher plow P/T fuse blows - sometimes ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Not a tractor problem but a 3 cable Fisher plow with isolation module in my truck. There is a 15 amp inline fuse from the battery to the iso module labled P/T (Park/Turn) fuse. This fuse blows a couple time a season and I lose the directionals and parking lights on the plow but the truck lights all still work. When I replace it every thing works fine. I have inspected the cable harnesses and connector/socket wiring and they all look good. I can't get into the iso module itself. Does any one have any suggestions on where else to look. I do run my emergency flashers w/ the lights on a lot but it seems a 15 amp fuse should run the four 1157 bulbs on the plow with both filaments on. (I am guessing that is what it does) . Thanks for any thoughts.
gg
   / Fisher plow P/T fuse blows - sometimes ?? #2
Typically something like that is the bulb sockets. Coat the socket and bulb base is petroleum jelly and make sure the lens baskets are good
   / Fisher plow P/T fuse blows - sometimes ?? #3
Gordon didn't you have an old fisher under hood belt drive pump?
Check out one of the snowplowing forums, they have "sections" for each brand's electrical gremlin questions. Snowplow Forums
   / Fisher plow P/T fuse blows - sometimes ?? #4
The connector between the plow and vehicle could also use some petroleum jelly
Thanks RN. I do use dielectric grease on the cable connectors and bulb bases. I am not sure what you mean by lens baskets. These are the four 1157 type bulbs in the head gear and everything seems solid.
gg
Thanks for that link Eric - Electrical Gremlin sounds like the right place to look !
This is just a straight 9' Minute-Mount 2 plow on my 2001 Ram 3500. That under the hood system was one that I took off an old Ford for a guy who wanted to restore the truck. I used the blade and A-frame on my tractor plow and ended up giving the pump and valve away as I couldn't fine any one who wanted to buy them.
gg
Blew the fuse again. This time when I carefully inspected the wiring again I actually took apart the lamp sockets. When I pushed one of the wires that went in the back of the socket out thru the front of the socket I found the problem. The wire was crimped onto the little bulb contact bead. Half the strands were in the crimp and half the strands were sticking out at a right angle with burnt ends. The thing went for several years before it started giving problems.
gg
   / Fisher plow P/T fuse blows - sometimes ?? #8
gg
Even a broken clock is right twice a day. I guess sometimes I get lucky!
Anyway, glad you found it. Some of those little gremlins are frustrating
I just thought you would find that amusing - I am the lucky one I figure.
gg
1991 Suzuki LT160 Quad Runner (A59814)
1991 Suzuki LT160...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
Eagle Weathervane (A55853)
Eagle Weathervane...
