Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,141
Just got myself set up. New to snow plowing. I have a 1300 ft gravel drive, of which 600 ft of it rises 120 ft. . Need some advice from experienced plow guys. I planned on driving down the middle of the drive from the top with the plow straight. Clearing the level area at the bottom and street side. Then driving back up the middle that was plowed and go back down on either side with the plow angled toward that ditch. Is this the correct way or am I missing something. I have to put some pics to honor the thread title so here they are.
View attachment 629191View attachment 629192View attachment 629193View attachment 629194
Nice setup for plowing, with the chains all around she should do good.
As far as pushing down with your blade straight that may or may not work for you.
I tend to plow towards the low side of my driveway, moving the snow to the edge of the bank or over it.
Not knowing your driveway it is hard to give advice, does it get drifting snow or does it go thru the woods which slow the drifting.
If you have tight turns it may be easier to push them out separately rather then while plowing the straights.
As far as the worn tires chains are better then traction thread tires most any time.
   / Pictures of your snow weapons #5,142
On my drive I tend to plow for the wind.
Everything goes to the east or south.
Helps a BUNCH on drifting.
   / Pictures of your snow weapons #5,143
I've noticed that if I try to plow with a straight blade eventually the snow that I'm trying to push becomes heavier than the truck and pushing becomes difficult. I always go with an angled blade unless I'm cleaning up a small amount. And I usually try to push it all to one side. Also don't try to plow tight turns like you were just driving. You'll end up crossing over your plow draft. Always try to be as straight as practical while pushing, it just seems to work better. As said before, plow for the wind. And don't pile the snow where it will get in the way. After a few thaw-freeze cycles you're not moving that pile very easily. Anticipate lots of snow and try to get it as far out of the way as possible so you don't end up with a narrow drive because it started coming in on you. One thing I've noticed when we get over 8" is that if I try to get it clean on the first pass it takes forever because the snow spills out both sides of the blade. So what I do is I plow the whole drive like I normally would letting it spill out the wrong side, then come back over again for a clean up. Like plowing the drive twice. It may seem counter-intuitive, but that's what seems to work best for me. Your first pass should be down hill. After the first pass you can take a half pass to go uphill if the snow is heavy.
Looks like you have some weight in the back, it is very helpful. I like having a trip-edge like yours instead of the whole blade tripping over. Also, with gravel make sure your shoes are set properly or you will be scooping up lots of gravel in the spring. And remember, you get stuck because you get hung up on snow. Don't get into snow deeper than your frame.
   / Pictures of your snow weapons #5,144
Hope to be helpful, but in your 3rd pic of the tire with chains, those chains do not fit the tire. The side chains should align like the 2nd pic. Trying to hold them on with bungee cord, I think you will walk right out of them in short order. But try it and see if it works for you.
For plowing your drive, decide which side you want a bank of snow.
I have a shallow drainage ditch on my left side of the drive and try to keep it clear of snow as much as possible. As snow piles up and some thawing and melting takes place, a buildup of ice can happen which hinders water drainage. That drainage happening out away from your ditch will/can cause some serious erosion to take place. And as mentioned, the direction of the wind needs to be considered. A high bank on the windward side will cause some serious snow drifts in your drive. Keep the high bank of snow on the downwind side wherever possible.
Good luck and enjoy the snow this winter.
   / Pictures of your snow weapons #5,145
If the drive is more than 2 blade widths across, the middle pass is probably needed.
Good thing you have 4 wheel chains since your tires are so worn.
Thanks for the advice.
Tires only have 8000 miles on them. Still have the nubs on the side of the tires.
   / Pictures of your snow weapons #5,146
Those chains are dead center on the tire. Totally different chains than on the rear. The chain that goes with the tire is supposed to be center of tread on a slight angle. If that makes sense.
   / Pictures of your snow weapons #5,147
Thanks for the advice. And yes, I put a load of firewood in the back. Gives me some weight and it can cure at the same time..
   / Pictures of your snow weapons #5,148
Kioti CK2610 & SB66 blower
Just waiting on the snow! IMG_20191103_133109392.jpegIMG_20191103_133138778.jpegIMG_20191103_133119389.jpeg
   / Pictures of your snow weapons #5,149
dpgoalie, beautiful setup you have. Everything looks brand new. How much clearing do you have to do?
   / Pictures of your snow weapons #5,150
When I operated a plow truck I always kept the back partially filled with sand and covered with a tarp.
Sand was always handy to have not counting the extra traction.
Having a bed liner I added some salt to keep it usable.
Also chained all 4's and at that often managed to get stuck. Even with 4 x 4.
All my drives were downhill towards waterfronts.
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
Hercules Gun Safe (A55853)
Hercules Gun Safe...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
