80mm hole to 90mm in 1/4" steel
   / 80mm hole to 90mm in 1/4" steel #21
I used a Milwaukee Hole Dozer (non carbide model) hole saw to drill 4 1/4" (108mm) in a couple 1/4" steel plates. I used a little bench top drill press and only had wd40 for lube. It worked much easier than expected, only taking a couple minutes. The saw still looks like new, with the only some pain rubbed off on the welded seam. I think I could probably use a hand drill if that's all I had. A mag drill would also work if you can rent one.
   / 80mm hole to 90mm in 1/4" steel #22
Found a carbide cutter 90mm hole saw on Amazon. You could use it to cut a hole in some wood, plastic, or metal to make a guide. Clamp or weld the guide over the 80mm hole and have at it.
Jeeez, I forgot to check in after the first reminder and did't suspect a ton of great advice already waiting. My apologies! Happens al he time, I wish I could get an alert on each reply.
I've done the tacked strip for a pilot hole before, also done the guide-bore holding hole made of plywood. The double hole-saw is news to me, never done that but it sure sounds like a good one too.
What worries me is the 1/4" (vertical) steel that I cannot put into a drill press. I'm scared that it's gonna take a day and who knows how many holesaws.
Also there is a new tag in the mix. The purpose of the holes is to fit the round lip of flange bearings into the side of a snowblower, 2 augers, hence 4 holes.
But since posting someone has suggested that the round lip is for alignment and not for housing support. My alignment can afford to be rough, like 1/8-1/4". The support is allegedly more than handled by four 1/2" bolts holding each housing to the blower body, so all I would need is a 1/4" thick washer to put around the lip with holes to pass the bolts through. This I could make out of polyethelene in minutes. I'd like to have this advice seconded though, the bearings cost 60 a piece and that alone is reason for prudence :)
Just in passing I finally managed to drill with a hole cutter in 1/4" aluminum in a drill press (unrelated job). I definitely would not want to try that in a 1/4" piece of steel that I can't even lay horizontal.
   / 80mm hole to 90mm in 1/4" steel #25
I'd rather cut steel than aluminum. I cut a 5" (127mm) hole with a hole saw in 1/4" aluminum a couple weeks ago, using a small drill press. That was a rough job, and much worse than cutting steel using the same setup. I got through it, but I wouldn't want to do that very often.
I'll have to give this a try sometime. Maybe I'll start with a confidence building drill-press exercise using steel, the OP issue has been settled though, I worked around it.
   / 80mm hole to 90mm in 1/4" steel #27
if you use a 5" hole saw for steel, use 65 RPM. too fast will cause problems. Hole saw RPMs so you cut the perfect hole as for Aluminum, a lubricant should be used to prevent the Aluminum from welding to the blade..
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
40' CONTAINER (A51248)
2019 John Deere S780 Combine (A53342)
2019 John Deere...
LMC LOT IDENTIFIER 130 (A53084)
LMC LOT IDENTIFIER...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
