LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,093
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Just got myself set up. New to snow plowing. I have a 1300 ft gravel drive, of which 600 ft of it rises 120 ft. . Need some advice from experienced plow guys. I planned on driving down the middle of the drive from the top with the plow straight. Clearing the level area at the bottom and street side. Then driving back up the middle that was plowed and go back down on either side with the plow angled toward that ditch. Is this the correct way or am I missing something. I have to put some pics to honor the thread title so here they are.
View attachment 629191View attachment 629192View attachment 629193View attachment 629194
Nice setup for plowing, with the chains all around she should do good.
As far as pushing down with your blade straight that may or may not work for you.
I tend to plow towards the low side of my driveway, moving the snow to the edge of the bank or over it.
Not knowing your driveway it is hard to give advice, does it get drifting snow or does it go thru the woods which slow the drifting.
If you have tight turns it may be easier to push them out separately rather then while plowing the straights.
As far as the worn tires chains are better then traction thread tires most any time.
