I think it's time to look for a harness.
   / I think it's time to look for a harness. #81
Fought it in court got it reduced to $5000 . Lawyer costed about $7000. I just paid the fine last week.
   / I think it's time to look for a harness. #83
My intended use to is to help stay on a sloped metal roof, not suspension from beams. I'll toss a tow/recovery strap over the roof peak and anchor it to ground on the other side. I'll hook this system to that and use this rope to maneuver up and down. I don't ever intend to allow enough slack to go off the edge for this to fully deploy.
My hand injury was not directly related to the fall from the ladder, but rather to catching it on the edge of the sheet metal roofing during the fall. I don't see this harness preventing that type of thing.
You can't use that strap for supporting any load. It's not meant to be used as fall restraint. It's fall arrest only. If you put any load on it, the stitching that keep it bunched together will start to get pulled out. Those stitches break sequentially to absorb the shock as you fall, as well as the fabric stretching. If one of those stitches gets cut, we have to send ours back to the factory for repair/replacement. That's why the plastic is on them. To keep the stitches from getting damaged.
That strap is 48" long and stretches to 72". So if you fall anywhere within 6' of the edge of the roof, you stand a good chance of slipping off the edge and dangling right around the soffits. Then, if you don't have foot supports, the harness will cut off the circulation in your legs, the blood will go into your legs and not be able to come back to your heart. You'll be dead in about 20 minutes without an escape plan, like a 2nd person to call 911, hope someone gets there with a ladder or something to get you down within that 20 minutes. That's why you need foot supports as well.
   / I think it's time to look for a harness. #84
Back in the day I walked construction iron 100 feet in the air without fall protection, day in, day out. I always thought through where I was going to fall and what I was going to grab onto if I did. I never fell, but times sure have changed. For the better, with the intent to get employees home to their family.
   / I think it's time to look for a harness. #85
We had a 105' Genie manlift that would bounce you out of the basket when driving around the plant since the first section of boom was so long. Plant policy superseded OSHA rules at the time.
   / I think it's time to look for a harness. #86
Boom Lift Catapult Europe 214 - YouTube
I think in a case like this I would rather be ejected than smashed against the machine with a leash.
Obviously, if you have a functioning brain, that shouldn't have happened.
   / I think it's time to look for a harness. #87
OSHA rules are a minimum, plant can enforce stricter rules
   / I think it's time to look for a harness. #88
   / I think it's time to look for a harness. #89
So, nice bright, Sunny, warm day and what am I doing? TBN!
Started checking out the bucket kit for the basket case (me). Went to unwrap things, get the razor knife out to slit the plastic .... then I see the Do Not Cut! I'm guessing this is like the emergency rip cord on a parachute that you hope NEVER unfurls?
The picture shows a part of the lanyard called a shock absorber. It reduces the shock to your body. Typically a sudden stop at the end of a lanyard can have forces of about 2000lbs put onto your body. A shock absorber reduces these forces to something your body can handle.
   / I think it's time to look for a harness. #90
This happened on a site I worked at. A person was thrown out of the basket, when he made a minor mistake. He died when he hit the ground, at the feet of his co-worker. The co-worker also happened to be his son.
2016 Morbark Beever M12R Towable Brush Chipper (A55787)
2016 Morbark...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2018 JLG 3246ES 32ft Electric Scissor Lift (A55787)
2018 JLG 3246ES...
Jumper Cables (A53316)
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
