fuse holder and switch search
   / fuse holder and switch search #1
Dutch445
Elite Member
Upstate NY
JD X585
trying to find the supplier for this switch with fuse assembly for a light, attempting to install rear work light and use
oem switch in the roof of the mauser cab on a JD 1025R,
price from supplier is not even comprehensible, possible language barrier!
here is the holder, and a pic of a switch in it's holder.. the holder contains the fuse.
   / fuse holder and switch search #2
Looks like aftermarket may be the way to go. You can get pretty nice fuse boxes from the marine industry.
   / fuse holder and switch search #3
JD can't get it for you??.. it seems they should be able to!..
   / fuse holder and switch search #4
If its not paramount to have the exact switch, go to FLAPS (Friendly Local Auto Parts) and get inline fuse holder and a generic rocker switch (with lED indicator) fabricate nice cover plate for old switch hole and mount new switch in cover plate....
Dale
   / fuse holder and switch search #5
   / fuse holder and switch search #6
Try checking out the links in this post. I didn't follow any of them but it looks like it has the answer to the same question you are asking.
SM
https://www.****************.com/fo...ht-mauser-factory-cab-equipped-installed.html
OK it didn't like to post the link maybe this .jpg.
totally unusable, ask a moderator why your link didn't post, maybe MossRoad? I've never seen this before without a comment on what happened, and I've been a Moderator at another site for a long time.. the ***** characters usually represent a banned word or site, but always I've seen that used with a comment to explain it!.. checking. https://www.****************.com/forums/content/ apparently, the staff don't like that site, since it has been banned without explanation!!..
   / fuse holder and switch search #7
   / fuse holder and switch search #8
replace the ************ with the word 'green tractor talk'
I tried that, it's been banned without explanation!. try posting the URL yourself, you'll see you get the ********.
   / fuse holder and switch search #9
click the link. Then go to the browser address box and replace the **************** with those banned words 'green tractor talk' without spaces, and hit enter.
Oh, you meant if you try to post the actual full url here. Yes it blocks any reference to that site here, even if I just type the words in a sentence like this: ****************
I'll try the same with another color. I like red, so: redtractortalk
:D
   / fuse holder and switch search #10
Nice idea. Beats digging around in a fuse block. I also like the relays with attached blade fuse holder.
Mayb it's an OEM thing. I looked on E-Bay and could find nothing like it. It would have been even better if they just shortened up the rocker switch to make the whole thing fit a standard Cole Hersey type opening.
I did find this at the other place, even with a manufacturer name. come to find out these same switches
are used in some Gator (Mauser made) cabs.. but pricey! $59 list for the switch and fuse holder.
thanks for the info, i was late returning to the thread.
we are going to just order in the Mauser rear led light kit, and use everything but the light (customer
provided his own bar style light).
   / fuse holder and switch search #12
A light switch for NH or CIH is $84. That makes the $59 price seem "reasonable". I was adding a switch to my dash and planned to use one to match the existing switches, until I priced them. I ended up using a generic switch for a fraction of the cost.
the switch is available on ebay, but delayed shipment from overseas... maybe we should buy a dozen and keep them on hand!
   / fuse holder and switch search #14
Could you provide a link or picture and desription/item number?.
   / fuse holder and switch search #17
Thanks. I was thinking you found something generic. So, is this design exclusive OEM to JD?
   / fuse holder and switch search #18
I am alwsya buying stuff from China. Bought a Cole Hersey Style LED rocker switch some time ago. I couldn't for the life of me figure the connections out and of course there was no documentation. Finally realized it had a regular bulb, not LED! Refund, no problem. Some of the descriptions are hilarious. One amp panel meter today is described as having no Fever!
   / fuse holder and switch search #20
I would NEVER want a meter with a fever!!..
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2023 KRT ST900HD STAND-ON SKID STEER (A60429)
2023 KRT ST900HD...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2003 McCormick XTX 185 XtraSpeed Tractor (A61307)
2003 McCormick XTX...
2463 (A60432)
2463 (A60432)
