Truck / trailer mounted crane
   / Truck / trailer mounted crane #11
Before cranes suitable for trucks were available, I used to see variations of this system on trucks.
The only photos I found were military.
Bruce
   / Truck / trailer mounted crane #12
Bruce
I’ve seen those for setting septic tanks but not for much else.
   / Truck / trailer mounted crane #13
Used to see similar units on trucks or trailer mounted to carry and set pre cast burial vaults in grave yards.
   / Truck / trailer mounted crane #14
I did a small one years ago with just a 4" pipe inside of a 4.25" pipe, adjustable boom length, #2500 electric winch, worked great but between the short height and the long tailgate I could barely lift over it, it did however work well for large rounds.
   / Truck / trailer mounted crane #16
Modified the base of this 2 ton truck crane to work in hitch receivers and allow extra jacks to support/level. Made it where I can easily break it down into three pieces to move. Can load anvils in back of truck or lift heavy stuff onto benches in shop. It came with a nice roller thrust bearing in the base for rotation and jam bolt to lock.
Remember cranes are made for lifting straight up......not side loads.
   / Truck / trailer mounted crane #18
Yep, that would be your hydraulic rotation:
   / Truck / trailer mounted crane #19
Something like this and it has its own trailer in a way.
   / Truck / trailer mounted crane #20
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
