What do you do with your Instant Pot you cant do with a crock pot?
   / What do you do with your Instant Pot you cant do with a crock pot? #131
   / What do you do with your Instant Pot you cant do with a crock pot? #132
Guess it could be a crap-shoot either way. We will probably continue to use both.
I suspect, whenever you get your watt meter back, that you use more kWH with the slow cooker.
Which watt meter do you use? I've got two of these, one in the house, one in the house. They're very handy and give you lots of information.
Poniie PN2000 Plug-in Kilowatt Electricity Usage Monitor Electrical Power Consumption Watt Meter Tester w/ Extension Cord https://www.amazon.com/dp/B0777H8MS8/ref=cm_sw_r_cp_tai_z7x.Db3MGM0K2
   / What do you do with your Instant Pot you cant do with a crock pot? #133
El chepo. https://www.amazon.com/P3-P4400-Ele...1576894541&sprefix=Kill+a+watt,aps,300&sr=8-4. Does everything I need it to do.
   / What do you do with your Instant Pot you cant do with a crock pot? #134
   / What do you do with your Instant Pot you cant do with a crock pot? #135
That is odd. Still pops right up for me.
   / What do you do with your Instant Pot you cant do with a crock pot? #136
Either method would cost way, way less than a normal tip at a restaurant around here. Plus you get a good yummy meal. I would not split electrons, there is a place for both in most kitchens.
   / What do you do with your Instant Pot you cant do with a crock pot? #138
When your electricity bill climbs up past $250 a month it may be time to split some of those electrons. It becomes important to save where you can. My income is fixed but my outlays are not.
   / What do you do with your Instant Pot you cant do with a crock pot? #139
Yikes! I guess I now understand. Around $100 / month down here (summer and winter) with our dam electricity on a 3000 sq ft house and 1000 sq ft shop. Jumps to around $120 in the 2 shoulder months when the heat pump runs (when not worth having the wood stove running).
   / What do you do with your Instant Pot you cant do with a crock pot? #140
Yikes! I guess I now understand. Around $100 / month down here (summer and winter) with our dam electricity. Jumps to around $120 in the 2 shoulder months when the heat pump runs (when not worth having the wood stove running).
Winter has been so mild that even we have been on Hydro up until now. Winter just showed up today -14F. Bills will increase now when they fire up those big Enterprise Power plants. Oh the Joy.
2007 Ford F-350 9FT Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
Crate of Motor Oil & Transmission Fluid (A56469)
Crate of Motor Oil...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
Electric Mobility Scooter (A55853)
Electric Mobility...
2019 Ford F-150 XL (A53317)
2019 Ford F-150 XL...
UNUSED FUTURE MINI EXCAVATOR (8) PC ATTACHMENT SET (A57193)
UNUSED FUTURE MINI...
